Date/Time: Thu, 02 May 2024 11:41:33 +0000
Changing Font Size of Volume Profile on DOM
View Count: 2188
[2019-09-29 20:54:35] |
User659208 - Posts: 22 |
Hello, Is there any way I can change the font size of my volume profile on the DOM? My volume font size is relatively bigger compared to the font size of DOM price. http://www.sierrachart.com/image.php?Image=1569790341873.png |
[2019-09-30 07:43:12] |
Yes, near the end of the description for this Input setting it explains how to do this: Volume By Price Study: Display Volume in Bars (Display Volume in Bars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-30 07:43:23
