Date/Time: Thu, 02 May 2024 09:12:46 +0000
Data
View Count: 514
[2019-09-29 20:12:06] |
conr - Posts: 204 |
Ver. 1987, Denali, ESZ19 I Duplicated all my charts to a new chartbook. After they all loaded, the exact same charts in both books are nothing but a black screen, no scales, nothing. They are two 3 minute charts and a 2 tick renko. All the other charts in both books are fine. I deleted all data and re-downloaded and same result. I shut down and restarted and same result. What I discovered was if I opened the chart settings window and loaded say 2, 5, 12 days etc. it loaded perfectly. Reset back to 4000 days and blank.
[2019-09-29 22:39:02] |
Maybe you are encountering an out of memory error condition: Working With Charts: Out of Memory Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
