Date/Time: Fri, 25 Sep 2026 20:51:41 +0000
Data Feed Re-Connection error
View Count: 922
| [2019-09-29 09:23:25] |
| User831216 - Posts: 2 |
Reading Internal Order ID file. | 2019-09-29 10:56:15.259 Reading Trade Orders file. | 2019-09-29 10:56:15.512 Reading Trade Positions file. | 2019-09-29 10:56:15.514 Reading Account Balance file. | 2019-09-29 10:56:15.517 UDPListener (1400). Port 22904 | Listening on UDP port 22904. | 2019-09-29 10:56:15.560 Software version: 1991 64-bit | 2019-09-29 10:56:15.577 Enabled for: Advanced Features 2. | 2019-09-29 10:56:15.577 Enabled for: Sierra Chart Historical Data Service. | 2019-09-29 10:56:15.577 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-09-29 10:56:15.577 Current selected Data/Trading service: Rithmic Trading | 2019-09-29 10:56:15.577 Custom symbol settings values: enabled | 2019-09-29 10:56:15.577 Chart Update Interval: 500 | 2019-09-29 10:56:15.577 Intraday Data Storage Time Unit: 0 | 2019-09-29 10:56:15.577 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2019-09-29 10:56:15.577 2019-09-29 10:56:15 Local computer time | 2019-09-29 10:56:15.577 2019-09-29 08:56:15 Local computer time in UTC | 2019-09-29 10:56:15.577 2019-09-29 10:56:15 Local computer time in SC Time Zone | 2019-09-29 10:56:15.577 2019-09-29 08:56:14 Server time in UTC | 2019-09-29 10:56:15.577 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-09-29 10:56:15.577 Program path: C:\SierraChart\ | 2019-09-29 10:56:15.577 Data Files path: C:\SierraChart\Data\ | 2019-09-29 10:56:15.577 OS Version Number: 10.0 | 2019-09-29 10:56:15.577 Locale Setting: C | 2019-09-29 10:56:15.577 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-09-29 10:56:15.577 Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2019-09-29 10:56:15.578 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:56:15.634 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-09-29 10:56:15.693 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-09-29 10:56:15.693 Received 5 login tokens. | 2019-09-29 10:56:15.792 Symbol settings MD5 received. Request ID: 1. | 2019-09-29 10:56:15.796 Symbol settings are up-to-date for rithmic.trading. | 2019-09-29 10:56:15.796 Rithmic Trading | Port for executable: 50163 | 2019-09-29 10:56:20.761 Listening socket (1404). Port 50163 | Closed. | 2019-09-29 10:56:20.761 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:20.762 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50163. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:21.905 Rithmic Trading | Bridge process is running. | 2019-09-29 10:56:23.907 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50163 | 2019-09-29 10:56:23.907 DTC Client socket (1) | Creating socket. | 2019-09-29 10:56:23.907 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:56:23.907 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:56:24.909 * DTC Client socket (1) | Closed. | 2019-09-29 10:56:24.909 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:56:24.909 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:24.909 Rithmic Trading | Disconnected. | 2019-09-29 10:56:24.919 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:24.919 Rithmic Trading | Port for executable: 50165 | 2019-09-29 10:56:26.917 Listening socket (1404). Port 50165 | Closed. | 2019-09-29 10:56:26.917 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:26.918 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50165. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:27.241 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:56:29.227 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50165 | 2019-09-29 10:56:29.227 DTC Client socket (1) | Creating socket. | 2019-09-29 10:56:29.227 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:56:29.227 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:56:30.228 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:56:30.229 DTC Client socket (1) | Closed. | 2019-09-29 10:56:30.229 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:30.229 Rithmic Trading | Disconnected. | 2019-09-29 10:56:30.251 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:30.251 Rithmic Trading | Port for executable: 50168 | 2019-09-29 10:56:32.253 Listening socket (1432). Port 50168 | Closed. | 2019-09-29 10:56:32.253 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:32.254 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50168. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:34.279 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:56:36.273 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50168 | 2019-09-29 10:56:36.273 DTC Client socket (1) | Creating socket. | 2019-09-29 10:56:36.273 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:56:36.273 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:56:37.275 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:56:37.275 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:37.275 DTC Client socket (1) | Closed. | 2019-09-29 10:56:37.275 Rithmic Trading | Disconnected. | 2019-09-29 10:56:37.289 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:37.289 Rithmic Trading | Port for executable: 50171 | 2019-09-29 10:56:39.306 Listening socket (1056). Port 50171 | Closed. | 2019-09-29 10:56:39.306 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:39.307 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50171. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:40.022 Rithmic Trading | Bridge process is running. | 2019-09-29 10:56:42.021 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50171 | 2019-09-29 10:56:42.021 DTC Client socket (1) | Creating socket. | 2019-09-29 10:56:42.021 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:56:42.021 Rithmic Trading | Connected to server. | 2019-09-29 10:56:42.524 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:56:42.524 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:56:42.534 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:56:42.573 Rithmic Trading | Sending logon request message. | 2019-09-29 10:56:42.573 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:56:42.575 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:56:42.577 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:56:42.577 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:56:45.992 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:56:46.236 Rithmic Trading | Received logon response. | 2019-09-29 10:56:46.236 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:56:46.236 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:56:46.236 Rithmic Trading | Logon error received from server | 2019-09-29 10:56:46.236 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:56:46.236 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:46.236 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:56:46.282 Rithmic Trading | Disconnected. | 2019-09-29 10:56:46.283 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:46.283 Rithmic Trading | Port for executable: 50187 | 2019-09-29 10:56:48.276 Listening socket (1404). Port 50187 | Closed. | 2019-09-29 10:56:48.276 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:48.277 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50187. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:48.333 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:56:50.321 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50187 | 2019-09-29 10:56:50.321 DTC Client socket (2) | Creating socket. | 2019-09-29 10:56:50.321 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:56:50.321 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:56:51.323 * DTC Client socket (2) | Closed. | 2019-09-29 10:56:51.324 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:56:51.324 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:51.324 Rithmic Trading | Disconnected. | 2019-09-29 10:56:51.337 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:51.337 Rithmic Trading | Port for executable: 50189 | 2019-09-29 10:56:53.341 Listening socket (1072). Port 50189 | Closed. | 2019-09-29 10:56:53.341 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:53.342 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50189. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:53.402 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:56:55.398 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50189 | 2019-09-29 10:56:55.398 DTC Client socket (2) | Creating socket. | 2019-09-29 10:56:55.398 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:56:55.398 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:56:56.403 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:56:56.403 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:56.403 DTC Client socket (2) | Closed. | 2019-09-29 10:56:56.403 Rithmic Trading | Disconnected. | 2019-09-29 10:56:56.417 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:56:56.417 Rithmic Trading | Port for executable: 50191 | 2019-09-29 10:56:58.425 Listening socket (1436). Port 50191 | Closed. | 2019-09-29 10:56:58.425 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:56:58.426 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50191. Current folder: C:\SierraChart\Rim | 2019-09-29 10:56:58.509 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:00.518 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50191 | 2019-09-29 10:57:00.518 DTC Client socket (2) | Creating socket. | 2019-09-29 10:57:00.518 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:00.518 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:01.519 * DTC Client socket (2) | Closed. | 2019-09-29 10:57:01.519 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:01.520 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:01.520 Rithmic Trading | Disconnected. | 2019-09-29 10:57:01.525 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:01.525 Rithmic Trading | Port for executable: 50196 | 2019-09-29 10:57:03.527 Listening socket (1072). Port 50196 | Closed. | 2019-09-29 10:57:03.527 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:03.527 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50196. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:05.259 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 10:57:07.161 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:57:07.161 DTC Client socket (1) | Closed. | 2019-09-29 10:57:07.161 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:07.267 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50196 | 2019-09-29 10:57:07.267 DTC Client socket (1) | Creating socket. | 2019-09-29 10:57:07.267 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:07.267 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:08.270 * DTC Client socket (1) | Closed. | 2019-09-29 10:57:08.270 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:08.270 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:08.270 Rithmic Trading | Disconnected. | 2019-09-29 10:57:08.279 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:08.279 Rithmic Trading | Port for executable: 50202 | 2019-09-29 10:57:10.277 Listening socket (1472). Port 50202 | Closed. | 2019-09-29 10:57:10.277 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:10.278 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50202. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:10.327 Rithmic Trading | Bridge process is running. | 2019-09-29 10:57:12.320 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50202 | 2019-09-29 10:57:12.320 DTC Client socket (1) | Creating socket. | 2019-09-29 10:57:12.320 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:12.321 Rithmic Trading | Connected to server. | 2019-09-29 10:57:12.322 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:57:12.322 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:57:12.565 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:57:12.567 Rithmic Trading | Sending logon request message. | 2019-09-29 10:57:12.567 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:57:12.570 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:57:12.574 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:57:12.574 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:57:14.874 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:57:15.107 Rithmic Trading | Received logon response. | 2019-09-29 10:57:15.107 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:57:15.107 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:57:15.108 Rithmic Trading | Logon error received from server | 2019-09-29 10:57:15.108 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:15.108 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:15.108 DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:57:17.534 Rithmic Trading | Message from server: Server Alert: PnL Connection Broken | 2019-09-29 10:57:17.547 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Broken | 2019-09-29 10:57:17.547 Rithmic Trading | Message from server: Deleting API object. | 2019-09-29 10:57:17.547 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-09-29 10:57:17.548 DTC Client socket (1) | Closed. | 2019-09-29 10:57:17.548 Rithmic Trading | Disconnected. | 2019-09-29 10:57:17.553 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:17.553 Rithmic Trading | Port for executable: 50220 | 2019-09-29 10:57:19.555 Listening socket (1016). Port 50220 | Closed. | 2019-09-29 10:57:19.555 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:19.556 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50220. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:23.947 Rithmic Trading | Bridge process is running. | 2019-09-29 10:57:25.947 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50220 | 2019-09-29 10:57:25.947 DTC Client socket (1) | Creating socket. | 2019-09-29 10:57:25.948 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:25.948 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:26.949 * DTC Client socket (1) | Closed. | 2019-09-29 10:57:26.949 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:26.949 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:26.949 Rithmic Trading | Disconnected. | 2019-09-29 10:57:26.966 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:26.966 Rithmic Trading | Port for executable: 50222 | 2019-09-29 10:57:28.972 Listening socket (1028). Port 50222 | Closed. | 2019-09-29 10:57:28.973 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:28.974 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50222. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:29.042 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:31.051 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50222 | 2019-09-29 10:57:31.051 DTC Client socket (1) | Creating socket. | 2019-09-29 10:57:31.051 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:31.052 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:32.056 * DTC Client socket (1) | Closed. | 2019-09-29 10:57:32.056 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:32.056 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:32.056 Rithmic Trading | Disconnected. | 2019-09-29 10:57:32.073 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:32.073 Rithmic Trading | Port for executable: 50224 | 2019-09-29 10:57:34.075 Listening socket (1072). Port 50224 | Closed. | 2019-09-29 10:57:34.075 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:34.077 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50224. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:34.168 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:36.169 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50224 | 2019-09-29 10:57:36.169 DTC Client socket (1) | Creating socket. | 2019-09-29 10:57:36.169 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:36.169 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:37.172 * DTC Client socket (1) | Closed. | 2019-09-29 10:57:37.173 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:37.173 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:37.173 Rithmic Trading | Disconnected. | 2019-09-29 10:57:37.183 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:37.183 Rithmic Trading | Port for executable: 50228 | 2019-09-29 10:57:39.182 Listening socket (1468). Port 50228 | Closed. | 2019-09-29 10:57:39.182 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:39.190 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50228. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:39.261 Rithmic Trading | Bridge process is running. | 2019-09-29 10:57:41.263 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50228 | 2019-09-29 10:57:41.263 DTC Client socket (1) | Creating socket. | 2019-09-29 10:57:41.263 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:41.263 Rithmic Trading | Connected to server. | 2019-09-29 10:57:41.264 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:57:41.264 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:57:41.285 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:57:41.286 Rithmic Trading | Sending logon request message. | 2019-09-29 10:57:41.286 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:57:41.288 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:57:41.290 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:57:41.290 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:57:43.365 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:57:43.612 Rithmic Trading | Received logon response. | 2019-09-29 10:57:43.612 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:57:43.612 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:57:43.612 Rithmic Trading | Logon error received from server | 2019-09-29 10:57:43.612 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:43.612 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:43.612 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:57:43.617 Rithmic Trading | Disconnected. | 2019-09-29 10:57:43.618 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:43.618 Rithmic Trading | Port for executable: 50245 | 2019-09-29 10:57:45.622 Listening socket (1452). Port 50245 | Closed. | 2019-09-29 10:57:45.622 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:45.623 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50245. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:45.696 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:47.703 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50245 | 2019-09-29 10:57:47.703 DTC Client socket (2) | Creating socket. | 2019-09-29 10:57:47.703 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:47.704 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:48.711 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:48.711 DTC Client socket (2) | Closed. | 2019-09-29 10:57:48.711 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:48.711 Rithmic Trading | Disconnected. | 2019-09-29 10:57:48.730 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:48.730 Rithmic Trading | Port for executable: 50247 | 2019-09-29 10:57:50.731 Listening socket (1452). Port 50247 | Closed. | 2019-09-29 10:57:50.731 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:50.732 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50247. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:50.798 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:52.800 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50247 | 2019-09-29 10:57:52.800 DTC Client socket (2) | Creating socket. | 2019-09-29 10:57:52.800 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:52.801 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:53.802 * DTC Client socket (2) | Closed. | 2019-09-29 10:57:53.802 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:53.802 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:53.802 Rithmic Trading | Disconnected. | 2019-09-29 10:57:53.804 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:53.804 Rithmic Trading | Port for executable: 50249 | 2019-09-29 10:57:55.806 Listening socket (1436). Port 50249 | Closed. | 2019-09-29 10:57:55.806 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:57:55.807 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50249. Current folder: C:\SierraChart\Rim | 2019-09-29 10:57:55.868 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:57:57.868 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50249 | 2019-09-29 10:57:57.868 DTC Client socket (2) | Creating socket. | 2019-09-29 10:57:57.868 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:57:57.869 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:57:58.872 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:57:58.872 DTC Client socket (2) | Closed. | 2019-09-29 10:57:58.872 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:58.872 Rithmic Trading | Disconnected. | 2019-09-29 10:57:58.883 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:57:58.883 Rithmic Trading | Port for executable: 50251 | 2019-09-29 10:58:00.888 Listening socket (1452). Port 50251 | Closed. | 2019-09-29 10:58:00.888 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:00.889 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50251. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:00.969 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:02.961 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50251 | 2019-09-29 10:58:02.961 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:02.961 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:02.961 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:03.963 * DTC Client socket (2) | Closed. | 2019-09-29 10:58:03.963 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:03.963 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:03.963 Rithmic Trading | Disconnected. | 2019-09-29 10:58:03.979 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:03.979 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 10:58:04.326 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:58:04.326 DTC Client socket (1) | Closed. | 2019-09-29 10:58:04.326 Rithmic Trading | Port for executable: 50253 | 2019-09-29 10:58:05.987 Listening socket (1436). Port 50253 | Closed. | 2019-09-29 10:58:05.987 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:05.988 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50253. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:06.060 Rithmic Trading | Bridge process is running. | 2019-09-29 10:58:08.056 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50253 | 2019-09-29 10:58:08.056 DTC Client socket (1) | Creating socket. | 2019-09-29 10:58:08.056 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:08.056 Rithmic Trading | Connected to server. | 2019-09-29 10:58:08.057 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:58:08.057 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:58:08.074 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:58:08.075 Rithmic Trading | Sending logon request message. | 2019-09-29 10:58:08.075 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:58:08.076 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:58:08.079 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:58:08.079 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:58:10.163 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:58:10.402 Rithmic Trading | Received logon response. | 2019-09-29 10:58:10.403 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:58:10.403 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:58:10.403 Rithmic Trading | Logon error received from server | 2019-09-29 10:58:10.403 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:10.403 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:10.403 Rithmic Trading | Disconnected. | 2019-09-29 10:58:10.415 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:10.415 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:58:10.415 Rithmic Trading | Port for executable: 50273 | 2019-09-29 10:58:12.423 Listening socket (1096). Port 50273 | Closed. | 2019-09-29 10:58:12.423 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:12.426 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50273. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:12.483 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:14.484 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50273 | 2019-09-29 10:58:14.484 DTC Client socket (3) | Creating socket. | 2019-09-29 10:58:14.484 DTC Client socket (3) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:14.485 DTC Client socket (3) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:15.487 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:15.487 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:15.487 DTC Client socket (3) | Closed. | 2019-09-29 10:58:15.487 Rithmic Trading | Disconnected. | 2019-09-29 10:58:15.495 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:15.495 Rithmic Trading | Port for executable: 50278 | 2019-09-29 10:58:17.498 Listening socket (1452). Port 50278 | Closed. | 2019-09-29 10:58:17.498 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:17.499 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50278. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:18.874 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:22.187 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50278 | 2019-09-29 10:58:22.187 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:22.187 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:22.187 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:23.190 * DTC Client socket (2) | Closed. | 2019-09-29 10:58:23.190 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:23.190 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:23.190 Rithmic Trading | Disconnected. | 2019-09-29 10:58:23.200 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:23.200 Rithmic Trading | Port for executable: 50280 | 2019-09-29 10:58:25.203 Listening socket (1476). Port 50280 | Closed. | 2019-09-29 10:58:25.203 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:25.204 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50280. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:25.258 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:27.266 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50280 | 2019-09-29 10:58:27.266 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:27.266 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:27.266 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:28.268 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:28.268 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:28.268 DTC Client socket (2) | Closed. | 2019-09-29 10:58:28.268 Rithmic Trading | Disconnected. | 2019-09-29 10:58:28.278 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:28.278 Rithmic Trading | Port for executable: 50282 | 2019-09-29 10:58:30.290 Listening socket (1480). Port 50282 | Closed. | 2019-09-29 10:58:30.290 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:30.290 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50282. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:30.348 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 10:58:31.132 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:58:31.132 DTC Client socket (1) | Closed. | 2019-09-29 10:58:31.132 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:32.343 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50282 | 2019-09-29 10:58:32.343 DTC Client socket (1) | Creating socket. | 2019-09-29 10:58:32.343 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:32.343 DTC Client socket (1) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:33.351 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:33.351 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:33.351 DTC Client socket (1) | Closed. | 2019-09-29 10:58:33.351 Rithmic Trading | Disconnected. | 2019-09-29 10:58:33.367 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:33.367 Rithmic Trading | Port for executable: 50284 | 2019-09-29 10:58:35.371 Listening socket (1492). Port 50284 | Closed. | 2019-09-29 10:58:35.371 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:35.372 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50284. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:35.429 Rithmic Trading | Bridge process is running. | 2019-09-29 10:58:37.415 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50284 | 2019-09-29 10:58:37.415 DTC Client socket (1) | Creating socket. | 2019-09-29 10:58:37.415 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:37.415 Rithmic Trading | Connected to server. | 2019-09-29 10:58:37.416 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:58:37.416 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:58:37.433 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:58:37.434 Rithmic Trading | Sending logon request message. | 2019-09-29 10:58:37.434 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:58:37.436 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:58:37.438 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:58:37.438 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:58:39.595 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:58:39.854 Rithmic Trading | Received logon response. | 2019-09-29 10:58:39.855 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:58:39.855 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:58:39.855 Rithmic Trading | Logon error received from server | 2019-09-29 10:58:39.855 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:39.855 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:39.855 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:58:39.889 Rithmic Trading | Disconnected. | 2019-09-29 10:58:39.889 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:39.890 Rithmic Trading | Port for executable: 50304 | 2019-09-29 10:58:41.886 Listening socket (1452). Port 50304 | Closed. | 2019-09-29 10:58:41.886 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:41.886 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50304. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:41.938 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:43.934 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50304 | 2019-09-29 10:58:43.934 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:43.934 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:43.934 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:44.935 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:44.935 DTC Client socket (2) | Closed. | 2019-09-29 10:58:44.935 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:44.935 Rithmic Trading | Disconnected. | 2019-09-29 10:58:44.946 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:44.946 Rithmic Trading | Port for executable: 50307 | 2019-09-29 10:58:46.954 Listening socket (1500). Port 50307 | Closed. | 2019-09-29 10:58:46.954 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:46.955 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50307. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:47.010 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:49.017 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50307 | 2019-09-29 10:58:49.017 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:49.017 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:49.018 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:50.020 * DTC Client socket (2) | Closed. | 2019-09-29 10:58:50.020 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:50.020 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:50.020 Rithmic Trading | Disconnected. | 2019-09-29 10:58:50.025 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:50.025 Rithmic Trading | Port for executable: 50309 | 2019-09-29 10:58:52.035 Listening socket (1484). Port 50309 | Closed. | 2019-09-29 10:58:52.035 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:52.036 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50309. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:52.090 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:54.100 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50309 | 2019-09-29 10:58:54.100 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:54.100 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:54.100 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:58:55.101 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:58:55.102 DTC Client socket (2) | Closed. | 2019-09-29 10:58:55.102 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:55.102 Rithmic Trading | Disconnected. | 2019-09-29 10:58:55.117 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:58:55.117 Rithmic Trading | Port for executable: 50312 | 2019-09-29 10:58:57.122 Listening socket (1500). Port 50312 | Closed. | 2019-09-29 10:58:57.122 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:58:57.124 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50312. Current folder: C:\SierraChart\Rim | 2019-09-29 10:58:57.161 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:58:59.149 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50312 | 2019-09-29 10:58:59.149 DTC Client socket (2) | Creating socket. | 2019-09-29 10:58:59.149 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:58:59.150 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:00.152 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:00.152 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:00.152 DTC Client socket (2) | Closed. | 2019-09-29 10:59:00.153 Rithmic Trading | Disconnected. | 2019-09-29 10:59:00.166 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:00.166 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 10:59:00.490 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:59:00.490 DTC Client socket (1) | Closed. | 2019-09-29 10:59:00.490 Rithmic Trading | Port for executable: 50314 | 2019-09-29 10:59:02.168 Listening socket (1496). Port 50314 | Closed. | 2019-09-29 10:59:02.169 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:02.170 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50314. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:02.209 Rithmic Trading | Bridge process is running. | 2019-09-29 10:59:04.207 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50314 | 2019-09-29 10:59:04.207 DTC Client socket (1) | Creating socket. | 2019-09-29 10:59:04.207 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:04.208 Rithmic Trading | Connected to server. | 2019-09-29 10:59:04.209 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:59:04.209 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:59:04.213 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:59:04.214 Rithmic Trading | Sending logon request message. | 2019-09-29 10:59:04.214 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:59:04.216 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:59:04.220 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:59:04.220 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:59:06.297 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:59:06.541 Rithmic Trading | Received logon response. | 2019-09-29 10:59:06.541 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:59:06.541 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:59:06.541 Rithmic Trading | Logon error received from server | 2019-09-29 10:59:06.541 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:06.541 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:06.541 Rithmic Trading | Disconnected. | 2019-09-29 10:59:06.579 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:06.579 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:59:06.579 Rithmic Trading | Port for executable: 50330 | 2019-09-29 10:59:08.578 Listening socket (1404). Port 50330 | Closed. | 2019-09-29 10:59:08.578 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:08.578 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50330. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:08.625 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:10.617 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50330 | 2019-09-29 10:59:10.617 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:10.618 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:10.618 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:11.619 * DTC Client socket (2) | Closed. | 2019-09-29 10:59:11.620 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:11.620 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:11.620 Rithmic Trading | Disconnected. | 2019-09-29 10:59:11.633 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:11.633 Rithmic Trading | Port for executable: 50336 | 2019-09-29 10:59:13.648 Listening socket (1516). Port 50336 | Closed. | 2019-09-29 10:59:13.648 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:13.650 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50336. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:13.698 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:15.700 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50336 | 2019-09-29 10:59:15.700 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:15.700 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:15.700 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:16.702 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:16.702 DTC Client socket (2) | Closed. | 2019-09-29 10:59:16.702 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:16.702 Rithmic Trading | Disconnected. | 2019-09-29 10:59:16.712 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:16.712 Rithmic Trading | Port for executable: 50339 | 2019-09-29 10:59:18.716 Listening socket (1528). Port 50339 | Closed. | 2019-09-29 10:59:18.716 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:18.717 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50339. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:18.755 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:20.744 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50339 | 2019-09-29 10:59:20.744 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:20.744 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:20.745 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:21.749 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:21.749 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:21.749 DTC Client socket (2) | Closed. | 2019-09-29 10:59:21.749 Rithmic Trading | Disconnected. | 2019-09-29 10:59:21.765 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:21.765 Rithmic Trading | Port for executable: 50341 | 2019-09-29 10:59:23.770 Listening socket (1516). Port 50341 | Closed. | 2019-09-29 10:59:23.770 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:23.771 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50341. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:23.811 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:25.805 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50341 | 2019-09-29 10:59:25.805 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:25.805 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:25.805 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:26.808 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:26.808 DTC Client socket (2) | Closed. | 2019-09-29 10:59:26.808 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:26.808 Rithmic Trading | Disconnected. | 2019-09-29 10:59:26.828 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:26.828 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 10:59:27.272 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:59:27.272 DTC Client socket (1) | Closed. | 2019-09-29 10:59:27.272 Rithmic Trading | Port for executable: 50348 | 2019-09-29 10:59:28.825 Listening socket (1500). Port 50348 | Closed. | 2019-09-29 10:59:28.825 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:28.825 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50348. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:28.917 Rithmic Trading | Bridge process is running. | 2019-09-29 10:59:30.913 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50348 | 2019-09-29 10:59:30.913 DTC Client socket (1) | Creating socket. | 2019-09-29 10:59:30.913 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:30.914 Rithmic Trading | Connected to server. | 2019-09-29 10:59:30.915 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:59:30.915 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:59:30.915 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:59:30.917 Rithmic Trading | Sending logon request message. | 2019-09-29 10:59:30.917 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:59:30.919 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:59:30.921 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:59:30.921 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:59:33.041 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:59:33.293 Rithmic Trading | Received logon response. | 2019-09-29 10:59:33.293 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:59:33.293 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:59:33.293 Rithmic Trading | Logon error received from server | 2019-09-29 10:59:33.293 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:33.293 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:33.293 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 10:59:33.324 Rithmic Trading | Disconnected. | 2019-09-29 10:59:33.324 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:33.324 Rithmic Trading | Port for executable: 50362 | 2019-09-29 10:59:35.326 Listening socket (1516). Port 50362 | Closed. | 2019-09-29 10:59:35.326 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:35.327 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50362. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:35.382 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:37.372 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50362 | 2019-09-29 10:59:37.372 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:37.372 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:37.372 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:38.375 * DTC Client socket (2) | Closed. | 2019-09-29 10:59:38.377 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:38.377 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:38.377 Rithmic Trading | Disconnected. | 2019-09-29 10:59:38.386 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:38.386 Rithmic Trading | Port for executable: 50368 | 2019-09-29 10:59:40.387 Listening socket (1524). Port 50368 | Closed. | 2019-09-29 10:59:40.387 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:40.388 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50368. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:40.438 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:42.431 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50368 | 2019-09-29 10:59:42.431 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:42.431 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:42.431 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:43.434 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:43.434 DTC Client socket (2) | Closed. | 2019-09-29 10:59:43.434 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:43.434 Rithmic Trading | Disconnected. | 2019-09-29 10:59:43.447 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:43.447 Rithmic Trading | Port for executable: 50376 | 2019-09-29 10:59:45.449 Listening socket (1456). Port 50376 | Closed. | 2019-09-29 10:59:45.449 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:45.450 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50376. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:45.495 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:47.497 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50376 | 2019-09-29 10:59:47.497 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:47.497 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:47.497 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:48.498 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:48.498 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:48.498 DTC Client socket (2) | Closed. | 2019-09-29 10:59:48.498 Rithmic Trading | Disconnected. | 2019-09-29 10:59:48.509 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:48.509 Rithmic Trading | Port for executable: 50378 | 2019-09-29 10:59:50.515 Listening socket (1504). Port 50378 | Closed. | 2019-09-29 10:59:50.515 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:50.517 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50378. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:50.570 Rithmic Trading | Bridge process is not running! | 2019-09-29 10:59:52.570 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50378 | 2019-09-29 10:59:52.570 DTC Client socket (2) | Creating socket. | 2019-09-29 10:59:52.571 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:52.571 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 10:59:53.572 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:53.572 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:53.572 DTC Client socket (2) | Closed. | 2019-09-29 10:59:53.572 Rithmic Trading | Disconnected. | 2019-09-29 10:59:53.588 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:53.588 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 10:59:54.034 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:59:54.034 DTC Client socket (1) | Closed. | 2019-09-29 10:59:54.034 Rithmic Trading | Port for executable: 50380 | 2019-09-29 10:59:55.592 Listening socket (1452). Port 50380 | Closed. | 2019-09-29 10:59:55.592 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 10:59:55.594 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50380. Current folder: C:\SierraChart\Rim | 2019-09-29 10:59:55.637 Rithmic Trading | Bridge process is running. | 2019-09-29 10:59:57.641 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50380 | 2019-09-29 10:59:57.641 DTC Client socket (1) | Creating socket. | 2019-09-29 10:59:57.641 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 10:59:57.641 Rithmic Trading | Connected to server. | 2019-09-29 10:59:57.642 Rithmic Trading | Starting socket receive thread. | 2019-09-29 10:59:57.642 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 10:59:57.643 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 10:59:57.645 Rithmic Trading | Sending logon request message. | 2019-09-29 10:59:57.645 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 10:59:57.646 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 10:59:57.650 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 10:59:57.650 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 10:59:59.733 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 10:59:59.979 Rithmic Trading | Received logon response. | 2019-09-29 10:59:59.979 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 10:59:59.979 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 10:59:59.979 Rithmic Trading | Logon error received from server | 2019-09-29 10:59:59.979 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:59:59.979 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:59:59.979 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:00:00.019 Rithmic Trading | Disconnected. | 2019-09-29 11:00:00.019 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:00.020 Rithmic Trading | Port for executable: 50391 | 2019-09-29 11:00:02.020 Listening socket (1496). Port 50391 | Closed. | 2019-09-29 11:00:02.020 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:02.022 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50391. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:02.070 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:04.081 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50391 | 2019-09-29 11:00:04.081 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:04.081 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:04.081 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:05.084 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:05.084 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:05.084 DTC Client socket (2) | Closed. | 2019-09-29 11:00:05.084 Rithmic Trading | Disconnected. | 2019-09-29 11:00:05.085 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:05.086 Rithmic Trading | Port for executable: 50393 | 2019-09-29 11:00:07.092 Listening socket (1496). Port 50393 | Closed. | 2019-09-29 11:00:07.092 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:07.093 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50393. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:07.141 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:09.142 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50393 | 2019-09-29 11:00:09.142 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:09.142 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:09.142 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:10.148 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:10.148 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:10.148 DTC Client socket (2) | Closed. | 2019-09-29 11:00:10.148 Rithmic Trading | Disconnected. | 2019-09-29 11:00:10.164 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:10.164 Rithmic Trading | Port for executable: 50402 | 2019-09-29 11:00:12.167 Listening socket (1512). Port 50402 | Closed. | 2019-09-29 11:00:12.167 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:12.168 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50402. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:12.215 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:14.213 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50402 | 2019-09-29 11:00:14.213 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:14.213 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:14.214 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:15.215 * DTC Client socket (2) | Closed. | 2019-09-29 11:00:15.215 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:15.215 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:15.215 Rithmic Trading | Disconnected. | 2019-09-29 11:00:15.228 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:15.228 Rithmic Trading | Port for executable: 50409 | 2019-09-29 11:00:17.234 Listening socket (1524). Port 50409 | Closed. | 2019-09-29 11:00:17.234 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:17.236 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50409. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:17.285 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:19.280 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50409 | 2019-09-29 11:00:19.280 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:19.280 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:19.280 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:20.285 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:20.285 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:20.285 DTC Client socket (2) | Closed. | 2019-09-29 11:00:20.285 Rithmic Trading | Disconnected. | 2019-09-29 11:00:20.295 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:20.295 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:00:20.698 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:00:20.698 DTC Client socket (1) | Closed. | 2019-09-29 11:00:20.698 Rithmic Trading | Port for executable: 50411 | 2019-09-29 11:00:22.296 Listening socket (1504). Port 50411 | Closed. | 2019-09-29 11:00:22.296 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:22.298 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50411. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:22.353 Rithmic Trading | Bridge process is running. | 2019-09-29 11:00:24.362 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50411 | 2019-09-29 11:00:24.362 DTC Client socket (1) | Creating socket. | 2019-09-29 11:00:24.363 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:24.364 Rithmic Trading | Connected to server. | 2019-09-29 11:00:24.365 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:00:24.365 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:00:24.365 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:00:24.367 Rithmic Trading | Sending logon request message. | 2019-09-29 11:00:24.367 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:00:24.369 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:00:24.372 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:00:24.372 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:00:26.472 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:00:26.718 Rithmic Trading | Received logon response. | 2019-09-29 11:00:26.718 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:00:26.718 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:00:26.718 Rithmic Trading | Logon error received from server | 2019-09-29 11:00:26.718 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:26.718 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:26.718 Rithmic Trading | Disconnected. | 2019-09-29 11:00:26.737 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:26.737 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:00:26.737 Rithmic Trading | Port for executable: 50422 | 2019-09-29 11:00:28.731 Listening socket (1488). Port 50422 | Closed. | 2019-09-29 11:00:28.731 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:28.732 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50422. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:28.786 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:30.775 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50422 | 2019-09-29 11:00:30.775 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:30.775 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:30.775 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:31.779 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:31.779 DTC Client socket (2) | Closed. | 2019-09-29 11:00:31.779 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:31.779 Rithmic Trading | Disconnected. | 2019-09-29 11:00:31.790 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:31.790 Rithmic Trading | Port for executable: 50428 | 2019-09-29 11:00:33.797 Listening socket (1504). Port 50428 | Closed. | 2019-09-29 11:00:33.797 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:33.798 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50428. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:33.899 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:35.900 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50428 | 2019-09-29 11:00:35.900 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:35.900 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:35.900 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:36.914 * DTC Client socket (2) | Closed. | 2019-09-29 11:00:36.914 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:36.914 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:36.914 Rithmic Trading | Disconnected. | 2019-09-29 11:00:36.929 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:36.929 Rithmic Trading | Port for executable: 50433 | 2019-09-29 11:00:38.933 Listening socket (1456). Port 50433 | Closed. | 2019-09-29 11:00:38.933 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:38.934 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50433. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:38.990 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:40.978 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50433 | 2019-09-29 11:00:40.978 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:40.978 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:40.978 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:41.980 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:41.981 DTC Client socket (2) | Closed. | 2019-09-29 11:00:41.981 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:41.981 Rithmic Trading | Disconnected. | 2019-09-29 11:00:41.996 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:41.996 Rithmic Trading | Port for executable: 50441 | 2019-09-29 11:00:43.997 Listening socket (1548). Port 50441 | Closed. | 2019-09-29 11:00:43.997 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:43.998 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50441. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:44.050 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:46.046 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50441 | 2019-09-29 11:00:46.046 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:46.046 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:46.046 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:47.047 * DTC Client socket (2) | Closed. | 2019-09-29 11:00:47.048 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:47.048 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:47.048 Rithmic Trading | Disconnected. | 2019-09-29 11:00:47.058 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:47.058 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:00:47.418 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:00:47.418 DTC Client socket (1) | Closed. | 2019-09-29 11:00:47.418 Rithmic Trading | Port for executable: 50443 | 2019-09-29 11:00:49.066 Listening socket (1540). Port 50443 | Closed. | 2019-09-29 11:00:49.066 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:49.067 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50443. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:49.110 Rithmic Trading | Bridge process is running. | 2019-09-29 11:00:51.111 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50443 | 2019-09-29 11:00:51.111 DTC Client socket (1) | Creating socket. | 2019-09-29 11:00:51.111 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:51.111 Rithmic Trading | Connected to server. | 2019-09-29 11:00:51.112 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:00:51.112 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:00:51.112 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:00:51.114 Rithmic Trading | Sending logon request message. | 2019-09-29 11:00:51.114 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:00:51.116 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:00:51.118 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:00:51.118 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:00:53.211 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:00:53.460 Rithmic Trading | Received logon response. | 2019-09-29 11:00:53.460 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:00:53.460 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:00:53.460 Rithmic Trading | Logon error received from server | 2019-09-29 11:00:53.460 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:53.460 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:53.460 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:00:53.480 Rithmic Trading | Disconnected. | 2019-09-29 11:00:53.480 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:53.480 Rithmic Trading | Port for executable: 50454 | 2019-09-29 11:00:55.481 Listening socket (1548). Port 50454 | Closed. | 2019-09-29 11:00:55.481 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:00:55.483 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50454. Current folder: C:\SierraChart\Rim | 2019-09-29 11:00:55.524 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:00:57.526 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50454 | 2019-09-29 11:00:57.526 DTC Client socket (2) | Creating socket. | 2019-09-29 11:00:57.526 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:00:57.526 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:00:58.527 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:00:58.528 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:58.528 DTC Client socket (2) | Closed. | 2019-09-29 11:00:58.528 Rithmic Trading | Disconnected. | 2019-09-29 11:00:58.545 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:00:58.545 Rithmic Trading | Port for executable: 50456 | 2019-09-29 11:01:00.547 Listening socket (1488). Port 50456 | Closed. | 2019-09-29 11:01:00.547 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:01:00.548 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50456. Current folder: C:\SierraChart\Rim | 2019-09-29 11:01:00.587 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:01:02.586 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50456 | 2019-09-29 11:01:02.586 DTC Client socket (2) | Creating socket. | 2019-09-29 11:01:02.586 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:01:02.587 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:01:03.588 * DTC Client socket (2) | Closed. | 2019-09-29 11:01:03.588 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:01:03.588 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:01:03.588 Rithmic Trading | Disconnected. | 2019-09-29 11:01:03.607 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:01:03.607 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:01:14.169 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:01:14.169 DTC Client socket (1) | Closed. | 2019-09-29 11:01:14.169 Rithmic Trading | Port for executable: 50503 | 2019-09-29 11:02:20.905 Listening socket (1540). Port 50503 | Closed. | 2019-09-29 11:02:20.905 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:02:20.906 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50503. Current folder: C:\SierraChart\Rim | 2019-09-29 11:02:20.946 Rithmic Trading | Bridge process is running. | 2019-09-29 11:02:22.959 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50503 | 2019-09-29 11:02:22.959 DTC Client socket (1) | Creating socket. | 2019-09-29 11:02:22.959 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:02:22.959 Rithmic Trading | Connected to server. | 2019-09-29 11:02:22.960 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:02:22.960 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:02:22.960 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:02:22.962 Rithmic Trading | Sending logon request message. | 2019-09-29 11:02:22.962 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:02:22.963 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:02:22.967 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:02:22.967 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:02:25.134 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:02:25.377 Rithmic Trading | Received logon response. | 2019-09-29 11:02:25.377 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:02:25.377 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:02:25.377 Rithmic Trading | Logon error received from server | 2019-09-29 11:02:25.377 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:02:25.377 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:02:25.377 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:02:25.425 Rithmic Trading | Disconnected. | 2019-09-29 11:02:25.425 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:02:25.426 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:02:46.004 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:02:46.004 DTC Client socket (1) | Closed. | 2019-09-29 11:02:46.004 Rithmic Trading | Port for executable: 50564 | 2019-09-29 11:04:25.420 Listening socket (1540). Port 50564 | Closed. | 2019-09-29 11:04:25.420 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:04:25.420 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50564. Current folder: C:\SierraChart\Rim | 2019-09-29 11:04:25.466 Rithmic Trading | Bridge process is running. | 2019-09-29 11:04:27.463 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50564 | 2019-09-29 11:04:27.463 DTC Client socket (1) | Creating socket. | 2019-09-29 11:04:27.463 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:04:27.463 Rithmic Trading | Connected to server. | 2019-09-29 11:04:27.464 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:04:27.464 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:04:27.464 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:04:27.467 Rithmic Trading | Sending logon request message. | 2019-09-29 11:04:27.467 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:04:27.469 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:04:27.471 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:04:27.471 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:04:29.571 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:04:29.825 Rithmic Trading | Received logon response. | 2019-09-29 11:04:29.826 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:04:29.826 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:04:29.826 Rithmic Trading | Logon error received from server | 2019-09-29 11:04:29.826 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:04:29.826 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:04:29.826 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:04:29.896 Rithmic Trading | Disconnected. | 2019-09-29 11:04:29.897 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:04:29.897 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:04:50.537 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:04:50.537 DTC Client socket (1) | Closed. | 2019-09-29 11:04:50.537 Rithmic Trading | Port for executable: 50615 | 2019-09-29 11:06:29.887 Listening socket (1564). Port 50615 | Closed. | 2019-09-29 11:06:29.887 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:06:29.888 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50615. Current folder: C:\SierraChart\Rim | 2019-09-29 11:06:29.949 Rithmic Trading | Bridge process is running. | 2019-09-29 11:06:31.947 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50615 | 2019-09-29 11:06:31.947 DTC Client socket (1) | Creating socket. | 2019-09-29 11:06:31.947 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:06:31.947 Rithmic Trading | Connected to server. | 2019-09-29 11:06:31.949 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:06:31.949 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:06:31.949 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:06:31.951 Rithmic Trading | Sending logon request message. | 2019-09-29 11:06:31.951 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:06:31.952 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:06:31.955 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:06:31.955 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:06:34.141 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:06:34.399 Rithmic Trading | Received logon response. | 2019-09-29 11:06:34.400 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:06:34.400 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:06:34.400 Rithmic Trading | Logon error received from server | 2019-09-29 11:06:34.400 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:06:34.400 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:06:34.400 Rithmic Trading | Disconnected. | 2019-09-29 11:06:34.418 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:06:34.418 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:06:34.418 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:06:55.054 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:06:55.054 DTC Client socket (1) | Closed. | 2019-09-29 11:06:55.054 Rithmic Trading | Port for executable: 50648 | 2019-09-29 11:07:37.648 Listening socket (1544). Port 50648 | Closed. | 2019-09-29 11:07:37.648 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:07:37.649 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50648. Current folder: C:\SierraChart\Rim | 2019-09-29 11:07:37.697 Rithmic Trading | Bridge process is running. | 2019-09-29 11:07:39.695 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50648 | 2019-09-29 11:07:39.695 DTC Client socket (1) | Creating socket. | 2019-09-29 11:07:39.695 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:07:39.696 Rithmic Trading | Connected to server. | 2019-09-29 11:07:39.696 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:07:39.696 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:07:39.697 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:07:39.699 Rithmic Trading | Sending logon request message. | 2019-09-29 11:07:39.699 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:07:39.700 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:07:39.702 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:07:39.702 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:07:41.787 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:07:42.035 Rithmic Trading | Received logon response. | 2019-09-29 11:07:42.035 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:07:42.035 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:07:42.035 Rithmic Trading | Logon error received from server | 2019-09-29 11:07:42.035 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:07:42.035 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:07:42.035 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:07:42.082 Rithmic Trading | Disconnected. | 2019-09-29 11:07:42.082 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:07:42.082 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:08:02.761 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:08:02.761 DTC Client socket (1) | Closed. | 2019-09-29 11:08:02.761 Rithmic Trading | Port for executable: 50714 | 2019-09-29 11:09:42.079 Listening socket (1564). Port 50714 | Closed. | 2019-09-29 11:09:42.079 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:09:42.079 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50714. Current folder: C:\SierraChart\Rim | 2019-09-29 11:09:42.127 Rithmic Trading | Bridge process is running. | 2019-09-29 11:09:44.124 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50714 | 2019-09-29 11:09:44.124 DTC Client socket (1) | Creating socket. | 2019-09-29 11:09:44.124 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:09:44.124 Rithmic Trading | Connected to server. | 2019-09-29 11:09:44.125 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:09:44.125 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:09:44.125 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:09:44.175 Rithmic Trading | Sending logon request message. | 2019-09-29 11:09:44.175 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:09:44.176 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:09:44.179 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:09:44.179 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:09:46.272 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:09:46.515 Rithmic Trading | Received logon response. | 2019-09-29 11:09:46.515 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:09:46.515 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:09:46.515 Rithmic Trading | Logon error received from server | 2019-09-29 11:09:46.515 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:09:46.515 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:09:46.515 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:09:46.567 Rithmic Trading | Disconnected. | 2019-09-29 11:09:46.567 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:09:46.567 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:10:07.187 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:10:07.187 DTC Client socket (1) | Closed. | 2019-09-29 11:10:07.187 Rithmic Trading | Port for executable: 50774 | 2019-09-29 11:11:46.556 Listening socket (1536). Port 50774 | Closed. | 2019-09-29 11:11:46.556 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:11:46.557 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50774. Current folder: C:\SierraChart\Rim | 2019-09-29 11:11:46.597 Rithmic Trading | Bridge process is running. | 2019-09-29 11:11:48.585 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50774 | 2019-09-29 11:11:48.585 DTC Client socket (1) | Creating socket. | 2019-09-29 11:11:48.585 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:11:48.586 Rithmic Trading | Connected to server. | 2019-09-29 11:11:48.587 Rithmic Trading | Starting socket receive thread. | 2019-09-29 11:11:48.587 Rithmic Trading | Sending encoding request to server: Binary VLS | 2019-09-29 11:11:48.587 Rithmic Trading | Setting DTC encoding to Binary VLS | 2019-09-29 11:11:48.589 Rithmic Trading | Sending logon request message. | 2019-09-29 11:11:48.589 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2019-09-29 11:11:48.591 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2019-09-29 11:11:48.593 Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2019-09-29 11:11:48.593 Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:11:52.077 Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:11:52.357 Rithmic Trading | Received logon response. | 2019-09-29 11:11:52.357 Rithmic Trading | Server Name: DTC Bridge. | 2019-09-29 11:11:52.357 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2019-09-29 11:11:52.357 Rithmic Trading | Logon error received from server | 2019-09-29 11:11:52.357 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:11:52.357 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:11:52.357 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-09-29 11:11:52.409 Rithmic Trading | Disconnected. | 2019-09-29 11:11:52.409 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:11:52.409 Rithmic Trading | Port for executable: 50787 | 2019-09-29 11:12:00.656 Listening socket (1572). Port 50787 | Closed. | 2019-09-29 11:12:00.656 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2019-09-29 11:12:00.657 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50787. Current folder: C:\SierraChart\Rim | 2019-09-29 11:12:00.703 Rithmic Trading | Bridge process is not running! | 2019-09-29 11:12:02.701 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50787 | 2019-09-29 11:12:02.701 DTC Client socket (2) | Creating socket. | 2019-09-29 11:12:02.701 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-09-29 11:12:02.701 DTC Client socket (2) | Connect event error. Windows error code 10061: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. | 2019-09-29 11:12:03.703 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 11:12:03.703 DTC Client socket (2) | Closed. | 2019-09-29 11:12:03.703 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:12:03.703 Rithmic Trading | Disconnected. | 2019-09-29 11:12:03.714 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 11:12:03.714 DTC Client socket (1) | Close event error. Windows error code 10053: Eine bestehende Verbindung wurde softwaregesteuert durch den Hostcomputer abgebrochen. | 2019-09-29 11:12:11.666 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-09-29 11:12:11.666 DTC Client socket (1) | Closed. | 2019-09-29 11:12:11.666 |
| [2019-09-29 23:01:13] |
This may have been a problem over the weekend with the Rithmic server. This is not something we can help with: Rithmic Trading | Message from server: Server Alert: Market Data Connection Broken | 2019-09-29 11:02:25.134
Rithmic Trading | Message from server: Server Alert: Trading System Connection Broken | 2019-09-29 11:02:25.377 Rithmic Trading | Received logon response. | 2019-09-29 11:02:25.377 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
