Date/Time: Sun, 02 Feb 2025 17:05:11 +0000
Computer Crashed
View Count: 598
[2019-09-28 19:20:39] |
Emoya78 - Posts: 10 |
Hi, my computer crashed. I need to setup a the Sierra chart on a different computer. How would I go about doing that?
[2019-09-29 07:41:13] |
You just install it from this page: Software Download If you are able to access the Sierra Chart files on your computer that encountered a problem, you can move them to the new system. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-29 07:41:37
