Date/Time: Fri, 03 May 2024 06:51:49 +0000
Chart Right MArgin
View Count: 874
[2019-09-27 14:42:54] |
User168596 - Posts: 10 |
Hi, I try to fix a margin on the right side on chart, in order that do not overlap the volume profile that I have in the right side.. I look configurarion but I do not found it. REgards. encontré |
[2019-09-27 19:17:59] |
John - SC Support - Posts: 31334 |
You need to set the bars to where you want them so you can see your Volume by Price profile, then turn on Lock Fill Space. Refer to the documentation here: Working With Charts: Locking the Right Side Fill Space For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
