Date/Time: Wed, 27 Nov 2024 17:54:46 +0000
Passing alerts to an external program with parameters
View Count: 1031
[2019-09-27 14:38:08] |
UnixManiac - Posts: 46 |
Hi, I am using the "Run Program When This Alert" option under "General Settings" -> "Alerts" tab. I see by default my external program is receiving only the Alert number as a parameter. Is there any way to pass any other alert info to the external program? |
[2019-09-28 08:54:05] |
What other parameter did you need?
[2019-09-28 10:21:25] |
Ideally parameters to get the info from the fields found in "Alert Manager", like "Type", "Source" and "Alert Text". This way external program can parse for example the raw string of "Alert Text" and get all the details. |
[2019-10-06 08:43:30] |
We will add these additional parameters.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-06 08:44:25
[2019-10-06 08:59:25] |
Much appreciated!
[2019-10-06 09:29:41] |
This will be out in the next release.
[2019-10-06 10:56:02] |
User106180 - Posts: 88 |
Thanks SC Engineering. I made a similar request over a week ago here - symbol alerts storage location | Post: 192805
Date Time Of Last Edit: 2019-10-06 10:56:29
[2019-10-06 10:57:27] |
That is not the same request, and also it was made from an expired account.
[2023-07-11 23:56:23] |
User352451 - Posts: 3 |
Hey Sierra Chart Engineering - love how you guys always work on community items. Was wondering, was this request implemented? I am looking for a way to pass the spreadsheet formula results to external program as parameters. For example... 1. Trading: Position Average Price 2. Trading: Profit/Loss Text 3. Trading: Daily Profit/Loss Any ideas? |
[2023-07-16 15:51:11] |
Sierra_Chart Engineering - Posts: 17197 |
You can develop whatever you require using ACSIL. Refer to: ACSIL Programming Concepts: Direct Programmatic Interaction with Spreadsheet Sheets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
