Date/Time: Fri, 03 May 2024 12:21:21 +0000
How to Create Lines Between The Whole and Half Pivot Points?
View Count: 526
[2019-09-27 04:17:10] |
User344276 - Posts: 65 |
I have the Pivot Point Daily study on my chart on a 5 minute chart and have plotted the whole and half pivot points on my chart (S1, S1.5, S2, S2.5, R1, R1.5, R2, and R2.5, and so forth). Due to the volatility of the markets I notice there is considerable space between the whole and half pivot points. Is there a way I can create lines between the whole and half pivot points? What I mean is a line between S1 and S1.5, and R1 and R1.5, and so forth? Thank you.
[2019-09-27 16:11:21] |
Yes. Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-27 17:45:08
