Date/Time: Fri, 03 May 2024 11:34:11 +0000
CTS T4 Data populating in SC but pricing incorrect - Please Help
View Count: 646
[2019-09-27 02:03:42] |
User149065 - Posts: 12 |
I finally got "Data" to populate but the prices are way off. Using T4 on my other computer ES data for Dec Contract is running 2.50 higher at this time and earlier was 2.50 lower than same chart on T4. Using T4 data but in SC. Is there a setting I can check? SC SCREENSHOT http://prntscr.com/pbjb7e T4 Screenshot http://prntscr.com/pbjb7e Thanks in advance both software using same data feed |
[2019-09-27 04:52:18] |
The symbol of the chart is incorrect. You need to translate the symbols to the CTS symbols with Edit >> Translate Symbols to Current Service. Refer to: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
