Date/Time: Sat, 17 Oct 2026 01:05:59 +0000
Can't connect my SC to CTS T4 Topstep Trader Combine Sim Acct Data Feed
View Count: 869
[2019-09-26 22:32:41]
User149065 - Posts: 14
Hi all
I hope I can get some help here. I am having issues with connecting CTS T4 data into Sierracharts. I read the connection instructions and they seem straight forward enough. I paid for a level 5 membership and I have a working T4 Trading Combine that has working CTS Data.
Here is the message I received. I followed the instructions on how to enter the data into SC and used my username and password as well as the firm name for Topstep Trader that is used with my T4 acct (ptp). Thank you in advance for any help to connect.
TRIED TO ENTER PER INSTRUCTIONS BUT I GET ERROR MESSAGE;
Reading Internal Order ID file. | 2019-09-26 14:53:02.128
Reading Trade Orders file. | 2019-09-26 14:53:02.223
Reading Trade Positions file. | 2019-09-26 14:53:02.224
Reading Account Balance file. | 2019-09-26 14:53:02.224
UDPListener (1424). Port 22904 | Listening on UDP port 22904. | 2019-09-26 14:53:02.243
Software version: 1991 32-bit | 2019-09-26 14:53:02.243
Usage end date: 2019-10-27 | 2019-09-26 14:53:02.243
Enabled for: Advanced Features 2. | 2019-09-26 14:53:02.243
Enabled for: Sierra Chart Historical Data Service. | 2019-09-26 14:53:02.243
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-09-26 14:53:02.243
Current selected Data/Trading service: CTS T4 FIX | 2019-09-26 14:53:02.243
Custom symbol settings values: enabled | 2019-09-26 14:53:02.243
Chart Update Interval: 500 | 2019-09-26 14:53:02.243
Intraday Data Storage Time Unit: 0 | 2019-09-26 14:53:02.243
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-09-26 14:53:02.243
2019-09-26 14:53:02 Local computer time | 2019-09-26 14:53:02.243
2019-09-26 21:53:02 Local computer time in UTC | 2019-09-26 14:53:02.243
2019-09-26 14:53:02 Local computer time in SC Time Zone | 2019-09-26 14:53:02.243
2019-09-26 21:52:56 Server time in UTC | 2019-09-26 14:53:02.243
Local computer UTC time and Server UTC time difference: 5 seconds. | 2019-09-26 14:53:02.243
Program path: C:\SierraChart\ | 2019-09-26 14:53:02.243
Data Files path: C:\SierraChart\Data\ | 2019-09-26 14:53:02.243
OS Version Number: 10.0 | 2019-09-26 14:53:02.244
Locale Setting: C | 2019-09-26 14:53:02.244
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-09-26 14:53:02.244
Checking for new symbol settings. Requested symbol settings MD5 for service code cts. Request ID: 1. | 2019-09-26 14:53:02.244
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-09-26 14:53:02.262
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-09-26 14:53:02.429
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-09-26 14:53:02.429
Received 5 login tokens. | 2019-09-26 14:53:02.855
Symbol settings MD5 received. Request ID: 1. | 2019-09-26 14:53:02.962
Symbol settings are up-to-date for cts. | 2019-09-26 14:53:02.962
Files to Open on Start up | Opening file: ExampleChartbook.cht | 2019-09-26 14:53:05.953
CTS T4 FIX | Connection to non-affiliated broker not allowed. | 2019-09-26 14:53:07.952 *
FOR FIRM NAME I TRIED BOTH (PTP and ptp) Otherwise I just use my Username and PW from CTS-T4 as usual
PLEASE HELP ME
THANK YOU!
[2019-09-27 16:15:37]
You should be able to connect now because your Sierra Chart account is no longer affiliated with a broker. Try connecting again with File >> Connect to Data Feed.
