Date/Time: Sun, 02 Feb 2025 17:06:31 +0000
Volume profile next to every footprint
View Count: 2928
[2019-09-26 17:50:25] |
User232042 - Posts: 35 |
Hello, I'll attach an image of what I'm referring too. Basically to the right of each of the 1 min footprint candle, is a volume by price bar separated in the middle and with vbp extending in opposite directions. Thanks for looking into this.
Screen Shot 2019-09-26 at 10.44.54 AM.png / V - Attached On 2019-09-26 17:50:03 UTC - Size: 994.95 KB - 853 views |
[2019-09-26 17:58:30] |
How do I achieve this ? And one last question: Next to my 1 day TPO profile I have 1 day VBP for every day. How do I get the actual volume number to the left of VBP and also achieve no overlapping? Thanks for your help its very appreciated.
Screen Shot 2019-09-26 at 10.57.46 AM.png / V - Attached On 2019-09-26 17:58:07 UTC - Size: 191.11 KB - 473 views |
[2019-09-28 10:59:28] |
This can be done with the Numbers Bars study and using a second column for Numbers Bars which contains Column Background Type of the particular Volume Profile that you want. Refer to: Numbers Bars: Numbers Bars Background Types In regards to the second question, that is not supported. The volume numbers will always be displayed within the volume bars themselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-28 11:00:04
