Date/Time: Fri, 03 May 2024 12:45:12 +0000
10-Year Treasury Constant Maturity Minus 2-Year Treasury Constant Maturity (TNX)
View Count: 1361
[2019-09-26 15:14:29] |
Mack - Posts: 83 |
I'm interested in bonds. Specifically; 1: $TNX 2: Ten year, 2 year spread. Previously, I could plot the $TNX symbol with the Historical Data service, but now you need to enable CBOE Indices. Is this correct? Do you guys perhaps know of a way to plot the US 10 year, 2 year spread? It's an interesting indicator, as it refers to yield curve inversion. See more here: https://fred.stlouisfed.org/series/T10Y2Y |
[2019-09-26 21:21:54] |
Previously, I could plot the $TNX symbol with the Historical Data service, but now you No, this is not correct. Historical data for the symbol is accessible.need to enable CBOE Indices. Is this correct? There are different ways of doing a spread. A simple way would just be by using both of these studies: Add Additional Symbol https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=3#Difference_-_Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-26 21:22:45
