Date/Time: Mon, 06 May 2024 08:06:17 +0000
Trade Windows Request
View Count: 592
[2019-09-26 12:14:24] |
KXRCap - Posts: 52 |
SC - Love the new Separate Trade Windows - Balance/Orders/Positions etc. I have one request that is the Window Options you have only have "Always On top" as a format option. It would be great to have "Attach/Detach" and act more like a Quoteboard. Right now if you use "Alawys On Top" then when you switch Chartbooks it is always there. These Separate Trade Window have allowed me to build A nice Quote and Chart Trade Book. just would like to switch without always seeing it. Thanks
[2019-09-26 21:25:52] |
The Attach capability would only be able to attach one of these trading windows, to the main Sierra Chart window where the trading window would be considered owned by the main Sierra Chart window. The trading window would not be contained within the main Sierra Chart window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-26 21:26:18
[2019-09-26 23:02:30] |
Dear SC - I think you need to re-read that post... very circular and its windows! Its Possible. Here is a link to a quick video that shows the problem... essentially to use 2 chartbooks Say a Technical Book and a Quotes Book it takes about 11 mouse clicks to move. Once to eliminate the trade Windows and once to bring them back. Attached is a quick video. Again the Trade Windows are good... bit more ease of use and they would be great. |
TradeWindowsAlwaysOnTop.mp4 - Attached On 2019-09-26 23:00:49 UTC - Size: 7.77 MB - 283 views |
[2019-10-06 08:04:53] |
This is still not completely clear what you are showing, but we will add the capability to allow the trading information windows to be owned by the main window and allow them to be attached and detached.
