Date/Time: Tue, 22 Sep 2026 21:44:41 +0000
[Programming Help] - How to know that IB Trade workstation position was opened by ACSIL script?
View Count: 1277
| [2019-09-26 11:32:17] |
| User424475 - Posts: 3 |
For example script send sc.BuyEntry on chart with symbol name = "NIFTY50 IND-OPT-20190926-11450-C-NSE-1-INR-NIFTY" IB open position with symbol name = "NIFTY50-OPT-20190926-11450-C-NSE-1-INR" now if call s_SCPositionData pd; sc.GetTradePositionForSymbolAndAccount(pd, sc.Symbol, sc.SelectedTradeAccount); pd.PositionQuantity return 0.0 quantity -------------------------------------------- symbol name on IB not equal symbol name on Sierrachart -------------- how ACSIL script can know that this position was opened using sc.BuyEntry? how figure out correct symbol name to use in call to GetTradePositionForSymbolAndAccount? |
| [2019-09-26 21:23:52] |
Why not use this symbol when submitting the order: NIFTY50-OPT-20190926-11450-C-NSE-1-INR Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-09-27 05:20:36] |
if order send with symbol name "NIFTY50-OPT-20190926-11450-C-NSE-1-INR" IB open position with symbol name "NIFTY50-OPT-20190926 15:30 IST-11450-C-NSE-1-INR" ----------- I need found way to track positions opened by ASCIL script... ----------- question: why when specify incorrect symbol name (for exmaple "NIFTY50-OPT-20191003-11550-P-NSE-1-INR") it open position on IB with symbol name = "NIFTY50-OPT-20191003 15:30 IST-11550-P-NSE-1-INR"???? Date Time Of Last Edit: 2019-09-27 07:26:57
| [2019-09-28 08:53:47] |
We are going to fix this: 20190926 15:30 IST And filter out everything after the date. This will be out in the next release. We do not know the answer to your question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-09-28 17:17:16] |
should i use something like that? this turn string "NIFTY50 IND-OPT-20190926 15:30 IST-11450-C-NSE-1-INR" to "NIFTY50-OPT-20190926-11450-C-NSE-1-INR". SCString fixSymName(SCString str) { SCString array[1000]; int cnt=0; int s,e; s=0; bool end=false; while(true) { int e=str.IndexOf('-',s); if(e==-1) { e=str.GetLength(); end=true; } array[cnt]=str.GetSubString(e-s,s); int i=array[cnt].IndexOf(' '); if(i!=-1) array[cnt]=array[cnt].GetSubString(i,0); cnt++; if(end) break; s=e+1; } SCString out=array[0]; for(int k=1;k<cnt;k++) { out=out+"-"+array[k]; } return out; } ---------------- if(fixSymName(OrderDetails.Symbol).CompareNoCase(fixSymName(sc.GetTradeSymbol())) != 0) continue; if(fixSymName(PositionDetails.Symbol).CompareNoCase(fixSymName(sc.GetTradeSymbol())) != 0) continue; ---------------- ??? |
| [2019-09-30 19:56:18] |
This is a programming help question and we are totally declining it. We are not going to waste our valuable time with this Interactive Brokers crap like this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-30 19:56:36
