Date/Time: Tue, 11 Feb 2025 17:30:30 +0000
Issue With Order Allocation
View Count: 847
[2019-09-26 04:35:57] |
CodyH - Posts: 2 |
I have added a second account into my sierra and set up the order Allocation per the posted information. There is an issue, I can enter a position in both the accounts but am unable to exit the position in both accounts at the same time. (flatten/cancel/reverse) are all non-functioning. In addition, I can not remove the Order Confirmation for the secondary account. I have the Confirmations disabled, yet I get a confirmation when making a trade every time. |
[2019-09-26 22:02:52] |
In regards to Flatten and Reverse, is the aaccount you are doing that from, have a current Position? Support for Cancel All for order allocation to accounts will be implemented in the next release. Confirmations cannot be disabled in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-13 14:58:03] |
User100912 - Posts: 104 |
Can you please confirm if Order Allocation to Trade Accounts now supports attached orders, OCOs, flatten, and cancel? 2) Will there be a drop down in the Sierra Chart web trading interface to select account? Date Time Of Last Edit: 2020-09-13 16:06:17
[2020-09-14 18:48:52] |
No there is not full support for this like canceling orders. And some OCO order types are not supported. Order allocation to accounts is not supported on the web-based trading panel. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
