Date/Time: Fri, 03 May 2024 08:33:44 +0000
CTS
View Count: 485
[2019-09-25 21:11:23] |
Adam - Posts: 141 |
Hi im trying to connect (same PC) with my CTS feed and SC i cant find the use 'same hardware' check button referenced on step #8 here: https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Thanks |
[2019-09-26 22:01:28] |
In newer versions this setting is no longer available. This is mentioned here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
