Date/Time: Sun, 05 May 2024 05:35:54 +0000
Mensaje de Espera por Descarga de Datos Historicos
View Count: 605
[2019-09-25 16:35:05] |
Guillermo_Huerta - Posts: 2 |
Estimados: Continuamente me sale el mensaje de "Espera por descarga de Datos Historicos", y me bloquea constantemente las operaciones que estoy realizando, lo cual me incomoda muchísimo. Como puedo hacer para que solo se cargue una vez estos datos y no constantemente y a todo momento durante la sesión de operación. Saludos I continually get the "Wait for Historical Data Download" message, and it constantly blocks the operations I am doing, which makes me very uncomfortable. How can I do that this data is only loaded once and not constantly and at all times during the operation session. https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=31745 |
[2019-09-25 23:18:20] |
We believe that you are experiencing connectivity problems when using Rithmic. We definitely do not recommend you use Rithmic. We have more information about this here: https://www.sierrachart.com/index.php?page=doc/Rithmic.php#TechnicalSupportPolicy Tell us who your futures broker is and we will recommend another connectivity method. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
