Date/Time: Sun, 05 May 2024 06:51:31 +0000
Graph Draw Type is locked.
View Count: 559
[2019-09-25 14:01:29] |
AdrianB - Posts: 3 |
I'm using OBOI (on balance open interest) and I have been plotting it as a line graph because it will not let me change the graph draw type (1st attached image)and I want to be able to plot it as a basic candlestick chart. I use it on /ES in conjunction with the $TICK, both of which are plotted as candlesticks (2nd attached image) so it would be nice to have everything the same for ease of analysis. I'm wondering why it is locked as a custom graph draw type, and whether it is possible that we can change this. Thanks for all your help. |
Attachment Deleted. |
[2019-09-25 14:14:24] |
Most studies do not produce Open, High, Low, Close bars. To do those types of bars requires the use of this study: Study Overlay - OHLC (Open, High, Low, Close) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
