Date/Time: Sun, 24 Nov 2024 21:57:04 +0000
have trouble connecting to my external Data feed (Rithmic)
View Count: 1558
[2013-12-13 04:13:18] |
User77207 - Posts: 7 |
Hello there, can you please help me to connect to my data feed? Thank you, Vadim Rithmic 01 - Port for executable: 53757 | 2013-12-12 21:15:28 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:28 Rithmic 01: Connecting to the server 127.0.0.1. Port 53757 | 2013-12-12 21:15:29 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:30 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:30 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:30 Rithmic 01 - Port for executable: 54269 | 2013-12-12 21:15:31 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:31 Rithmic 01: Connecting to the server 127.0.0.1. Port 54269 | 2013-12-12 21:15:32 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:33 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:33 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:33 Rithmic 01 - Port for executable: 54781 | 2013-12-12 21:15:34 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:34 Rithmic 01: Connecting to the server 127.0.0.1. Port 54781 | 2013-12-12 21:15:35 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:36 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:36 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:36 Rithmic 01 - Port for executable: 56317 | 2013-12-12 21:15:37 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:37 Rithmic 01: Connecting to the server 127.0.0.1. Port 56317 | 2013-12-12 21:15:38 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:39 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:39 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:39 Rithmic 01 - Port for executable: 57341 | 2013-12-12 21:15:40 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:40 Rithmic 01: Connecting to the server 127.0.0.1. Port 57341 | 2013-12-12 21:15:41 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:42 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:42 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:42 Rithmic 01 - Port for executable: 61693 | 2013-12-12 21:15:43 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:43 Rithmic 01: Connecting to the server 127.0.0.1. Port 61693 | 2013-12-12 21:15:44 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:45 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:45 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:45 Rithmic 01 - Port for executable: 63485 | 2013-12-12 21:15:46 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:46 Rithmic 01: Connecting to the server 127.0.0.1. Port 63485 | 2013-12-12 21:15:47 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:48 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:48 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:48 Rithmic 01 - Port for executable: 63997 | 2013-12-12 21:15:49 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:49 Rithmic 01: Connecting to the server 127.0.0.1. Port 63997 | 2013-12-12 21:15:50 The network socket is connected. | 2013-12-12 21:15:50 Rithmic 01: Connected to server. | 2013-12-12 21:15:50 Rithmic 01: Sending logon request message. | 2013-12-12 21:15:50 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-12 21:15:50 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-12 21:15:50 Rithmic 01 - Connecting to Rithmic Production server. | 2013-12-12 21:15:50 Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-12-12 21:15:51 Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-12-12 21:15:51 Rithmic GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Rithmic GSP. | 2013-12-12 21:15:51 Rithmic GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-12 21:15:51 Rithmic GSP - Logon error from server: | 2013-12-12 21:15:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:51 Rithmic GSP: Disconnected from the server. | 2013-12-12 21:15:51 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:51 Rithmic 01 - Port for executable: 1278 | 2013-12-12 21:15:52 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:52 Rithmic 01: Connecting to the server 127.0.0.1. Port 1278 | 2013-12-12 21:15:53 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:15:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:54 Rithmic 01: Disconnected from the server. | 2013-12-12 21:15:54 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:54 Rithmic 01 - Port for executable: 3582 | 2013-12-12 21:15:55 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:55 Rithmic 01: Connecting to the server 127.0.0.1. Port 3582 | 2013-12-12 21:15:56 The network socket is connected. | 2013-12-12 21:15:56 Rithmic 01: Connected to server. | 2013-12-12 21:15:56 Rithmic 01: Sending logon request message. | 2013-12-12 21:15:56 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-12 21:15:56 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-12 21:15:56 Rithmic 01 - Connecting to Rithmic Production server. | 2013-12-12 21:15:56 Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-12-12 21:15:58 Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-12-12 21:15:58 Rithmic GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Rithmic GSP. | 2013-12-12 21:15:58 Rithmic GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-12 21:15:58 Rithmic GSP - Logon error from server: | 2013-12-12 21:15:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:15:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:15:58 Rithmic GSP: Disconnected from the server. | 2013-12-12 21:15:58 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:15:58 Rithmic 01 - Port for executable: 7166 | 2013-12-12 21:15:59 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:15:59 Rithmic 01: Connecting to the server 127.0.0.1. Port 7166 | 2013-12-12 21:16:00 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:16:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:16:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:16:01 Rithmic 01: Disconnected from the server. | 2013-12-12 21:16:01 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:16:01 Rithmic 01 - Port for executable: 7678 | 2013-12-12 21:16:02 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:16:02 Rithmic 01: Connecting to the server 127.0.0.1. Port 7678 | 2013-12-12 21:16:03 The network socket is connected. | 2013-12-12 21:16:03 Rithmic 01: Connected to server. | 2013-12-12 21:16:03 Rithmic 01: Sending logon request message. | 2013-12-12 21:16:03 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-12 21:16:03 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-12 21:16:03 Rithmic 01 - Connecting to Rithmic Production server. | 2013-12-12 21:16:03 Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-12-12 21:16:04 Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-12-12 21:16:04 Rithmic GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Rithmic GSP. | 2013-12-12 21:16:04 Rithmic GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-12 21:16:04 Rithmic GSP - Logon error from server: | 2013-12-12 21:16:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:16:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:16:04 Rithmic GSP: Disconnected from the server. | 2013-12-12 21:16:04 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:16:04 Rithmic 01 - Port for executable: 11774 | 2013-12-12 21:16:05 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:16:05 Rithmic 01: Connecting to the server 127.0.0.1. Port 11774 | 2013-12-12 21:16:06 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-12 21:16:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:16:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:16:07 Rithmic 01: Disconnected from the server. | 2013-12-12 21:16:07 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:16:07 Rithmic 01 - Port for executable: 12798 | 2013-12-12 21:16:08 Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-12-12 21:16:08 Rithmic 01: Connecting to the server 127.0.0.1. Port 12798 | 2013-12-12 21:16:09 The network socket is connected. | 2013-12-12 21:16:09 Rithmic 01: Connected to server. | 2013-12-12 21:16:09 Rithmic 01: Sending logon request message. | 2013-12-12 21:16:09 Rithmic 01 - Starting the connection process to data and trading service. | 2013-12-12 21:16:09 Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-12-12 21:16:09 Rithmic 01 - Connecting to Rithmic Production server. | 2013-12-12 21:16:09 Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-12-12 21:16:10 Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-12-12 21:16:11 Rithmic GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Rithmic GSP. | 2013-12-12 21:16:11 Rithmic GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-12 21:16:11 Rithmic GSP - Logon error from server: | 2013-12-12 21:16:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-12 21:16:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-12 21:16:11 Rithmic GSP: Disconnected from the server. | 2013-12-12 21:16:11 Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-12 21:16:11 Date Time Of Last Edit: 2013-12-13 04:55:24
[2013-12-13 09:37:19] |
This is the relevant error message: Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-12-12 21:15:51 Refer to step 15 here: https://www.sierrachart.com/index.php?l=doc/Rithmic.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
