Date/Time: Thu, 02 May 2024 10:27:16 +0000
Release of Delayed CME/CBOT/NYMEX/COMEX Data!
View Count: 9784
[2019-12-09 00:11:17] |
Crypto currencies are separate from the delayed futures data feed. And you may not have access to them when using a Sierra Chart account through a broker. We have to check on that. Historical market depth data is still not yet available. We will be getting to it as soon as we can. We are doing a software update now, and that is going to affect the delayed data feed. It will be interrupted for about 12 minutes or so. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-09 20:17:58] |
User132748 - Posts: 159 |
Could you confirm that depth is again only 100 levels for all exchanges besides crypto? Or this is per-user limit and I hit some threshold?
Date Time Of Last Edit: 2019-12-09 20:19:26
[2019-12-10 14:01:03] |
No that is not correct. It is up to 500 levels. Refer to this setting to control this: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-10 20:42:52] |
Thank you. I see full depth now.
[2020-01-23 18:18:49] |
User752471 - Posts: 14 |
Hey Sierra, from post #75, Historical market depth data is still not yet available. We will be getting to it as soon as we can. Any updates on this? Also if we are looking to run the chart replay feature using the delayed data feed on the SC Data - All Services (with Adv. Package 5 enabled), is there any way to get the market depth historical graph to feed data into it? or is this not possible at the moment? Everything seems to work in the replay feature except for the market depth historical graph not showing inventory and the DOMS not showing any inventory either (which would make sense as the market depth historical graph take data from the DOM). Thanks for your time and for providing such a robust platform! |
[2020-01-24 01:49:02] |
Sierra_Chart Engineering - Posts: 14173 |
It is our intent to get this out in 2020. Also if we are looking to run the chart replay feature using the delayed data feed on the SC Data - All Services (with Adv. Package 5 enabled), is there any way to get the market depth historical graph to feed data into it? Yes, if the market depth data has been recorded:Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-25 10:12:15] |
User320216 - Posts: 3 |
From the bottom of my heart to SC team. THANK YOU!
