Date/Time: Fri, 03 May 2024 08:36:19 +0000
SL TP 1 Click
View Count: 737
[2019-09-25 11:11:04] |
User231861 - Posts: 9 |
Hello ,Is It possible to configure the trade Dom to move sl or tp with a single click on price column? Thank you!! |
[2019-09-26 02:23:57] |
Refer to the documentation starting here for how to change prices of orders. Be sure to look through the sections following this one, as there is additional information: Chart Trading and the Chart DOM: Modifying and Canceling Orders on the Chart You cannot change both prices at the same time. They must be done separately. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-26 20:50:35] |
Thanks for your reply. I'm so sorry but I don't find what I need... Practically....move the stops like in Ninja platform...with a single click on price column is it possible or not ?? Thanks for your help!! |
[2019-09-27 07:53:26] |
Have a look at this functionality: Order Types: Move Attached Stops to Price (Move Attached Stops to Price) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
