Date/Time: Sat, 18 May 2024 07:13:45 +0000
what does it means ?
View Count: 535
[2019-09-24 23:04:01] |
User223358 - Posts: 6 |
Hi, What means this in the top left of my screen, in the green case ? DF:41 ST:2, 2 DL:0 ? Thanks, |
[2019-09-25 10:22:11] |
Refer to: Status Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
