Date/Time: Tue, 06 Oct 2026 05:07:29 +0000
[Programming Help] - Questions Regarding Multiple Instances
View Count: 1077
| [2019-09-24 17:53:35] |
| User148660 - Posts: 1 |
I am running a total of 3 instances locally. The basic package allows me to create these 3 instances, but I'm having trouble figuring out the following: - Does paying for "Additional Systems" here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation mean that I am buying more instances locally, more instances remotely, or both? - Does "2 systems included" mean that I can run 3 instances on 2 computers as is? So if I spin up a server using my account I can run a total of 6 instances (3 on each machine)? - Are there any limitations about how many instances I can create on one machine if I were to purchase them? - If not, could n instances all run backtests simultaneously without issue? This "additional systems" terminology is unclear, as to whether this service allows me to more than 3 instances locally. |
| [2019-09-25 09:30:25] |
You only need to pay for additional systems when you are using Sierra Chart on more than two computer systems. More information about this is here: Sierra Chart Purchase and License Information: Licensing / Number of Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
