Date/Time: Fri, 03 May 2024 03:49:32 +0000
User Email Question
View Count: 600
[2019-09-24 16:39:50] |
Sierra Chart - Max - Posts: 5599 |
I have a client that is looking for a platform that can enter MACD like in the picture (RealTick) Would that be possible with Sierra? Sierra Chart Support Date Time Of Last Edit: 2019-09-24 16:59:55
IMG_2199.JPG / V - Attached On 2019-09-24 16:44:32 UTC - Size: 5.89 MB - 250 views |
[2019-09-24 20:41:31] |
We need to look into this and we will get back to you on this.
[2019-09-26 20:34:32] |
SC Support Tom - Posts: 450 |
I have looked for documentation on RealTick (now known as Eze EMS), but to no avail. I am not sure that I understand the Inputs in the picture. I interpret the Signal Line to be the EMA of the MACD. What are the 1st and 2nd Lines? Are those the two terms in the definition of the MACD itself, ie the Fast and Slow EMAs of the Input Data? If so then it would be easy to offer the user the choice between entering Lengths and Percentages or Decimals (for example a Length of 8 would correspond roughly to a Percentage of 22.2 or a Decimal of 0.222).
Date Time Of Last Edit: 2019-09-26 20:35:56
