Date/Time: Sat, 18 May 2024 04:04:24 +0000
Will not allow me to upgrade from 1894 to 1987
View Count: 529
[2019-09-24 16:23:30] |
User464827 - Posts: 3 |
The installer also sent a log file of the errors https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=31724 |
[2019-09-25 10:06:08] |
We cannot reproduce this issue when installing version 1987. Although we do not want you to select the Specific Version option and just leave it at Current Version. And then try the installation again. It sounds like there probably is some communication problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
