Date/Time: Fri, 03 May 2024 13:58:00 +0000
Trade Activity Log
View Count: 514
[2019-09-24 12:13:42] |
User78442 - Posts: 260 |
I updated the SW version and the symbol settings have a different screen - I removed USD as the currency as I just want numerals in the Trade Activity log (see enclosed) - How do I get rid of the USD in the log as I import to an excel sheet - please advise
Private File Private File Attachment Deleted. |
[2019-09-24 12:16:46] |
You need to set this setting to None: Global Trade Settings Windows: Common Profit/Loss Currency (Global Settings >> General Trade Settings >> General) And do not modify the Symbol Setting that you did. That needs to continue to contain USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-24 12:16:54
[2019-09-24 12:23:23] |
Bingo..
[2019-09-25 12:31:58] |
I thought it was fixed but I had tagged the global commission. Once I removed this and just had a symbol commission included the commissions on the Activity log went to zero? Can you help? (see enc. the setting for ZB)
Private File |
[2019-09-26 00:18:50] |
Refer to the following: Trade Activity Log: Use Commission Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-26 04:05:19] |
