Date/Time: Sat, 18 May 2024 23:29:51 +0000
[Programming Help] - position closed incorrectly
View Count: 582
[2019-09-24 07:19:26] |
User625820 - Posts: 1 |
Please help me in case of incorrect closing of the position. The position closes about 25.4 P higher than the actual price of the stock. Attached screenshot of a closed position. I also noticed that Dom graph on charts is not drawing properly. Please help. |
Attachment Deleted. position closed.PNG / V - Attached On 2019-09-24 07:10:43 UTC - Size: 34.67 KB - 241 views |
[2019-09-24 10:59:22] |
Not totally sure about the incorrect fill price but we want you to want you to update to the current version of Sierra Chart following the instructions here: Software Download: Fast Update That is not going to correct an existing fill price though. We are not really sure in your case what the issue is with that. With the new connection that Sierra Chart has to Transact there is only the best bid and ask prices available. So you will only see two lines with the DOM Graph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-29 18:38:13
[2019-10-29 18:14:03] |
User690815 - Posts: 26 |
Engineering, are you saying it is Transact's problem? I see I'm not the only one experiencing this.
[2019-10-29 19:13:22] |
Yes and there are others experiencing the problem with incorrect bid and or ask prices from Transact. We did let them know about it.
