Date/Time: Sun, 02 Feb 2025 17:08:27 +0000
OneUp Combine - 30 days Free then what?
View Count: 689
[2019-09-23 23:21:38] |
User940942 - Posts: 9 |
I just started the OneUp Combine, and know that Sierra offers 30 days free. I have a few questions regarding this: 1. Does the 30 days include the full service package 5? 2. Once the 30 days is up, how would I continue to pay for service package 5 if I am not yet funded? 3. Once funded, how does paying for the package work or is that included with the OneUp funded account? On OneUp it mentions the data feed is free so I am thinking that it is handled on the back-end? 4. If I want to run multiple instances using the OneUp account, am I able to do this? After reading the section on using Multiple Copies of Sierra Chart, I was a little confused as it stated that you can use the same trading service but a different trading service account? Thank you in advance, ThunderKat |
[2019-09-24 15:55:48] |
John - SC Support - Posts: 37656 |
1. Yes, the trial gives you access to the full capabilities of Package 5. 2. You need to fund your Sierra Chart account. We do not have any special agreements with OneUp Trader apart from the trial period. You can add funds to your account from this link: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit 3. Again, this is your responsibility to pay for the Sierra Chart usage. According to their website, the data is from Rithmic, so as long as you have access to that data, you can use Sierra Chart with the Rithmic data. Refer to the information here for how to setup Sierra Chart for Rithmic: Rithmic Trading Platform Service 4. You can have 2 separate installations of Sierra Chart running at the same time on different computers. If you are just working with the one trading provider and need multiple instances, use the File >> New Instance option within Sierra Chart. This will use only the 1 data connection as well. Refer to the information here: Using DTC Server for Data and Trading in Another Sierra Chart Instance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-24 16:58:59
