Date/Time: Sun, 02 Feb 2025 14:53:02 +0000
Hidden indicators but Values seen?
View Count: 589
[2019-09-23 17:57:39] |
EuropeanTrader - Posts: 290 |
Hello, is it possible to hide Keltner channels for example (or any other indicator) but still see the value of its lines on the price axis? Thank you. Greg |
SH_ 4131 Sep. 23 19.55.jpg / V - Attached On 2019-09-23 17:57:16 UTC - Size: 154.3 KB - 280 views |
[2019-09-23 22:44:41] |
You need to change the Draw Style for the specific Subgraph that you want to show the value for to Subgraph Name and Value Labels Only. Refer to the following: Chart Studies: Subgraph Name and Value Labels Only (ACSIL: DRAWSTYLE_SUBGRAPH_NAME_AND_VALUE_LABELS_ONLY) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
