Date/Time: Sun, 02 Feb 2025 16:52:11 +0000
Trade activity log - default date
View Count: 673
[2019-09-23 16:22:36] |
User383849 - Posts: 23 |
Hi! I found myself needing to change the default date to Today when I open my Trade Activity Log each day when I start SC. How can I set "Today" as the default start date? Thanks! |
[2019-09-23 16:26:46] |
User13668 - Posts: 294 |
+1
[2019-09-23 17:23:10] |
nosast - Posts: 312 |
this would be really helpful!
[2019-09-23 21:39:52] |
We are not understanding this because there is on the Trade >>Trade Activity Log a Today checkbox which the state of is saved. There has never been a problem with this. And we verified that again now. It is saved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-23 23:03:51
[2019-09-24 06:34:46] |
Since the 1st day I use SC, the trade log will always view the last date I selected each time I opened up SC. Yes there's a Today checkbox which is not the issue. I'm referring to the FROM date which we need to change the date to current day each time we want to view "Today" trades. What we want is for SC to also change the default value for the FROM field. |
[2019-09-24 06:44:03] |
Example: Monday (Sep 23), the default FROM date when I open up SC was set to Friday (Sep 20). Today (Tue, Sep 24), the default FROM date when I open up SC was set to Monday (Sep 23). So each trading today with SC, I got to make sure I change the FROM date to Today or else my Trade Stats is not going to be accurately show only Today's trades. When I first started using SC, I asked a seasonal SC trader how to change this default behaviour and he said this is a bug and has never been fixed. I'm glad I'm not the only one facing this issue. |
[2019-09-24 10:01:32] |
I would also like the setting, that SC Trade Log shows ONLY the trades from current day (Today) to current day (Today) as the standard selected option.
[2019-09-24 11:01:10] |
I asked a seasonal SC trader how to change this default behaviour That's why you should never ask anyone else because they are telling you something that they do not properly understand. To call the saving of a particular field of information which is properly saved, a bug does not make any sense.and he said this is a bug and has never been fixed. We understand what you are looking for, and we will have to see about that later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
