Date/Time: Sun, 02 Feb 2025 16:49:31 +0000
Intrabar tick time for historical bars
View Count: 573
[2019-09-23 14:42:14] |
User99735 - Posts: 234 |
Hi, Is there a simpler way of getting the 'tick time' for historical bars, other than using sc.GetTimeSalesArrayIndexesForBarIndex()? Regards Vivek |
[2019-09-23 23:05:01] |
We do not understand the question.
