Date/Time: Sun, 09 Feb 2025 05:49:17 +0000
How to show full DOM depth again.
View Count: 1170
[2019-09-23 01:56:22] |
User731023 - Posts: 139 |
Uploaded version 1987 from 1881. DOM graph only shows 1 level of Bid and ask. Not all 10 like before? How to adjust please? Thanks |
[2019-09-23 06:30:25] |
You need to contact Transact about this. We cannot help with it. Other than to say the depth is not available and Transact says it will come at some point in the future.
[2019-09-23 11:14:48] |
Rino - Posts: 124 |
Went back to version 1881. It is beyond my understanding to why it works with version 1881 and not 1987. Thanks PS In future versions If/When Transact fixes problem please list in what is new. |
[2020-08-12 17:36:04] |
Rino - Posts: 124 |
What the crap... Bums me out that I can't use the current version. DOM graph still does not work on it. Once again why does it work on version 1881? Sorry for the crap comment. Just really dealing with some angst about it... |
[2020-08-12 23:05:02] |
Refer to the information here about this: https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccessingMarketDepthDataAndDailySessionValues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
