Date/Time: Fri, 19 Apr 2024 23:30:29 +0000
Can't load .cht file
View Count: 1126
[2019-09-22 09:14:27] |
User673725 - Posts: 12 |
Hi, I have been send a .cht file but can not get it to load. I copied it into the Data file but can get no further. I go to the Analysis tab and have then looked everywhere but can't find it. Can you help please. thanks James |
[2019-09-22 18:45:12] |
Do you see it listed in File >> Open Chartbook? If you have opened it, you need to make sure the symbols are correct. To do that, make sure the Chartbook is open, and then select Edit >> Translate Symbols to Current Service: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
