Date/Time: Sun, 02 Feb 2025 20:44:58 +0000
Study overlay from 60 min chart not aligning on another chart
View Count: 655
[2019-09-21 18:12:38] |
Woodzy - Posts: 32 |
I used studies to display hourly average range bands above and below the open of each 60 min bar. I want to display these on a lower timeframe chart but the alignment is not perfect when using study overlay. If you see the images attached it's easier to understand, but on the start on a new 60 min bar the overlay shifts back 30 mins. Obviously both charts are set to the same time period settings.
hour_range_1.png / V - Attached On 2019-09-21 18:11:51 UTC - Size: 182.9 KB - 296 views hour_range_2.png / V - Attached On 2019-09-21 18:12:00 UTC - Size: 158.17 KB - 309 views |
[2019-10-11 17:11:24] |
John - SC Support - Posts: 37656 |
We are sorry we did not get back to you right away on this. You need to change the Input for the Study/Price Overlay for Bar Time Matching Method to be Containing Match. Refer to the documentation here for this: Study/Price Overlay Study: Bar Time Matching Method For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
