Date/Time: Wed, 17 Apr 2024 23:52:56 +0000
Spreadsheet Study
View Count: 536
[2019-09-21 13:00:19] |
User441840 - Posts: 3 |
I'm trying to do a study with the daily OHLC and initial balance data. Is it possible to do such a study from the Daily time frame? When I'm on the daily chart the daily initial balance H/L data shows and outputs unto the spreadsheet as 0.0
[2019-09-22 20:07:43] |
The Initial Balance study is not designed to work on a chart with a Daily timeframe per bar. This is explained in the documentation here: Initial Balance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
