Date/Time: Thu, 02 May 2024 18:46:19 +0000
Orders / Positions Window
View Count: 485
[2019-09-20 14:06:28] |
AKR - Posts: 523 |
Is there a way to get them back into one window?
[2019-09-20 14:09:48] |
No. This is discontinued. If you want that type of style just simply resize them to be the same size and position them on top of each other. And then you can select which one you want through the Window menu of the active one.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-20 14:10:27
