Date/Time: Sun, 24 Nov 2024 23:08:06 +0000
3 day bars ( or 5 days)
View Count: 1490
[2013-12-12 19:32:05] |
pismo10 - Posts: 159 |
How can I draw a 3 Day bar chart that includes 18:00-16:15 for each day only for 3 days (or 5 days) So from 18:00 Mon night thru 16:15 Tues + 18:00 Tues night thru 16:15 Wed + 18:00 Wed night to 16:15 thursday = One bar. I also wnat to do 5 day the same way. Weekend same, start 18:00 Sun night, end 16:15 Fri. Thanks |
[2013-12-12 20:40:15] |
You should be able to accomplish this by using an Intraday chart. You will need to adjust the Session Times to what you require: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes And you will need to set the Days-Minutes-Seconds setting to 3-0-0. Refer to the Chart Settings documentation here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-12 21:20:23] |
Great, thank you. Actually, it is counting Sat and Sun as days. How do I get rid of that? I unchecked "Load Weekend Data" to no help. Now is there a way to make it rolling so each bar contains data for the last three days. Today is Thursday so today's bar after the 16:15 close has T,W,Th data combined. Yest Bar would have M,T,W combined etc Thanks Date Time Of Last Edit: 2013-12-12 21:31:47
[2013-12-16 05:08:24] |
Actually, it is counting Sat and Sun as days. There is not a way to avoid this.Now is there a way to make it rolling so each bar contains data for the last three days. https://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Refer to sc.IsCustomChart in the ACSIL documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-16 05:09:57
