Date/Time: Thu, 02 May 2024 23:20:38 +0000
Converting .scid file to .csv file
View Count: 1664
[2019-09-20 09:33:48] |
User14410 - Posts: 38 |
Hi, Can a .scid file be converted to .csv file format? |
[2019-09-20 09:35:31] |
Yes. Refer to: Edit Menu: Edit >> Export Intraday Data to Text file Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-20 09:40:20] |
But,Is it possible to convert the .scid file which has live data to .csv file format?
[2019-09-20 09:55:49] |
Yes another way to do it is with this study: Write Bar Data to File You will want to make sure that chart bars are set to the same timeframe as the Intraday Data Storage Time Unit you have set Sierra Chart to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-20 09:56:43
