Date/Time: Tue, 06 Oct 2026 03:41:05 +0000
Intraday Charts Blank - Except for example ones
View Count: 1197
[2019-09-19 12:04:42]
User966934 - Posts: 4
I have tried to use the intraday charting within Sierra, but for futures, ie CL and ES I can only get historical data, ie, daily, weekly, etc. I can not get intraday data. I have changed the server to TDA which I have, I have switched back to SC, I have used Quote Board and nothing, I have deleted and re-downloaded, in the chart settings I have intraday selected, I have tried intraday only, I have updated the trading time 00:00 - 23:59, I have looked at many posts and tried to fix accordingly.
Any help is greatly appreciated.
imageCapture.JPG / V - Attached On 2019-09-19 12:04:02 UTC - Size: 194.82 KB - 373 views
[2019-09-19 12:21:27]
Go to one of the blank charts and follow the instructions:
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
[2019-09-19 23:41:38]
Here you go, thank you!
Software version: 1987 64-bit | 2019-09-19 19:38:22.026
Usage end date: 2019-10-03 | 2019-09-19 19:38:22.026
Enabled for: Advanced Features 2. | 2019-09-19 19:38:22.026
Enabled for: Sierra Chart Historical Data Service. | 2019-09-19 19:38:22.026
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-09-19 19:38:22.026
Current selected Data/Trading service: SC Data - All Services | 2019-09-19 19:38:22.026
Custom symbol settings values: enabled | 2019-09-19 19:38:22.026
Chart Update Interval: 500 | 2019-09-19 19:38:22.026
Intraday Data Storage Time Unit: 1 | 2019-09-19 19:38:22.026
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-09-19 19:38:22.026
2019-09-19 19:38:22 Local computer time | 2019-09-19 19:38:22.026
2019-09-19 23:38:22 Local computer time in UTC | 2019-09-19 19:38:22.026
2019-09-19 19:38:22 Local computer time in SC Time Zone | 2019-09-19 19:38:22.026
2019-09-19 23:26:40 Server time in UTC | 2019-09-19 19:38:22.026
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-09-19 19:38:22.026
Program path: C:\SierraChart\ | 2019-09-19 19:38:22.026
Data Files path: C:\SierraChart\Data\ | 2019-09-19 19:38:22.026
OS Version Number: 10.0 | 2019-09-19 19:38:22.027
Locale Setting: C | 2019-09-19 19:38:22.027
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-09-19 19:38:22.027
Added Intraday data request for CLX19 to the queue. | 2019-09-19 19:38:51.049
Intraday data recording state for symbol CLX19 is set to download 'Pending'. | 2019-09-19 19:38:51.049
Triggering next historical data download in queue. | 2019-09-19 19:38:51.049
Reloading all charts with filename: CLX19.scid | 2019-09-19 19:38:51.049
HD Request # 11 | Downloading Intraday chart data for CLX19 to the file CLX19.scid. Service: nymex | 2019-09-19 19:38:51.049
HD Request # 11 | Download start date-time: 2019-03-17 19:38:51.000 | 2019-09-19 19:38:51.049
HD Request # 11 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2019-09-19 19:38:51.049
Socket (2) | Creating socket. | 2019-09-19 19:38:51.049
Socket (2) | Connecting to IP: 8.18.161.133. | 2019-09-19 19:38:51.049
HD Request # 11 | Setting DTC encoding to Binary VLS | 2019-09-19 19:38:51.172
HD Request # 11 | Sending historical data logon request message. | 2019-09-19 19:38:51.172
CLX19 1 Min #5 | Reloading chart. | 2019-09-19 19:38:51.216
HD Request # 11 | Requesting Intraday data. Start date-time: 2019-03-17 19:38:51. Record interval: 1. Symbol: CLX19 | 2019-09-19 19:38:51.220
CLX19 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\CLX19.scid | 2019-09-19 19:38:51.234
HD Request # 11 | Decompressing data. | 2019-09-19 19:38:51.271
HD Request # 11 | Receiving Intraday data for CLX19 starting at 2019-03-17 21:04:37 | 2019-09-19 19:38:51.422
HD Request # 11 | Timestamp of first Intraday data file record written: 2019-03-17 21:04:37 | 2019-09-19 19:38:51.424
Historical data download thread signaled to stop. | 2019-09-19 19:38:54.090
Socket (2) | Shutdown started. Waiting for graceful close. | 2019-09-19 19:38:54.090
HD Request # 11 | Received 468587 records from 2019-03-17 21:04:37.000 to 2019-09-19 19:28:32.000 (185.9 days) and wrote 468587 records for CLX19 | 2019-09-19 19:38:54.090
HD Request # 11 | Completion time: 3s | 2019-09-19 19:38:54.091
HD Request # 11 | Intraday data download complete for CLX19. Unique request ID: 10 | 2019-09-19 19:38:54.091
Removed historical data download ID 10 | 2019-09-19 19:38:54.091
Real-time Intraday chart data file updates started for CLX19 | 2019-09-19 19:38:54.091
Opened cached Intraday file: C:\SierraChart\Data\CLX19.scid | 2019-09-19 19:38:54.091
Intraday chart data file opened for CLX19 | 2019-09-19 19:38:54.092
Triggering next historical data download in queue. | 2019-09-19 19:38:54.092
Socket (2) | Socket gracefully closed by remote side. | 2019-09-19 19:38:54.132
Socket (2) | Closed. | 2019-09-19 19:38:54.132
[2019-09-20 08:54:19]
There is no problem with the historical data downloading. So therefore refer to this section:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Incorrect Chart and Session Times Settings (Incorrect Chart and Session Times Settings)
Date Time Of Last Edit: 2019-09-20 08:54:32
[2019-09-20 10:20:08]
I mentioned in my original post I have done this already.
[2019-09-20 10:37:51]
We want you to select File >> Close All Chartbooks.
And then open a new Intraday chart for CLX19. Do you then see the chart?
There simply should not be a problem with this at all. This is very straightforward and reliable.
[2019-09-25 10:27:36]
My apologies for the late reply - I only see historical information.
I just went through I ton of help pages, could it be because I don't have a paid service and I am using TDA for my live feed and I read that doesn't work well with Sierra?
[2019-09-26 22:16:41]
John - SC Support - Posts: 48114
Sierra Chart does not have support for TD Ameritrade Futures data or trading. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#Introduction
If you are just wanting futures data from the CME Group, then you can sign up for the Denali Real-Time Exchange Data Feed. Refer to the information here:
Denali Exchange Data Feed
