Date/Time: Sun, 02 Feb 2025 16:02:22 +0000
transparency for filled area between studies
View Count: 1316
[2019-09-19 07:50:05]
User710679 - Posts: 43
hi,
is there any way to increase the level of transparency of the filled area between studies ??
see pic attached
imageScreenshot_72.png / V - Attached On 2019-09-19 07:49:57 UTC - Size: 19.58 KB - 350 views
[2019-09-19 21:52:48]
Yes, use the fill options for the Draw Style that start with Transparent. Then the control in the bottom left of the Subgraphs Setting window for Transparency Level for Fill Styles controls the actual transparency value.
Refer to the following:
Chart Studies: Notes about Top and Bottom Draw Style Pairs
[2019-09-20 05:57:20]
works perfect! thanks
