Date/Time: Sun, 02 Feb 2025 16:09:51 +0000
At midnight the daily candle at 11:59:59 changed into a completely different candle
View Count: 705
[2019-09-19 04:58:44] |
User500792 - Posts: 18 |
And then the new days candle showed it traded in a range it never even traded in yet. The data turned off for a few seconds and then when it came back up, it showed completely different information than what was there a few seconds prior. The closing price of the daily candle is way off from the new day's opening price. How do I fix this so it never happens again? http://www.sierrachart.com/image.php?Image=1568868799685.png |
[2019-09-19 04:59:25] |
Refer to: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
