Date/Time: Sun, 02 Feb 2025 16:09:14 +0000
Spreadshet EMA Custom Calculation fails
View Count: 1198
[2019-09-19 03:02:08] |
User403758 - Posts: 25 |
Hello! I tried to get familar with the spreadsheet study. So I made some formulas in column K - ... (SMA, etc,) But I have no idea how to make the correct formula for EMA. I need the EMA in the formula columns because I want add the spreadsheet study to other study collection, so I don't want to use EMA as single study, I need EMA as formula. What I find in your documentation is this: Spreadsheet Example Formulas and Usage: Common Formulas and Usage But the presented formula suggests to use "P4", a cell which is empty by definition as I understand. So I get a long listing of NaN error. Can you help to implement the EMA via formula in the spreadsheet columns K - ...? Thanks! |
[2019-09-19 03:53:52] |
Sawtooth - Posts: 4164 |
Change all the P4s to K4s: =(E3 - K4) * (2 / (1 + $H$2)) + K4 where H2 is the Length. |
[2019-09-19 11:05:22] |
Hello tomgilb. Many thanks, it worked when I put the formula in cell K3. But why does this not work if I put the formula as before in another formula field? - I only get the correct result in K. All other columns make NaN error. Hm... |
[2019-09-19 13:06:24] |
It will work in any Formula Column's row 3. You just need to edit both column references to the column where the formula resides.
[2019-09-20 01:21:10] |
Hey, thank you very much! :) Last question, which make me struggeling. My custom SMA has a length of 100 => SMA(100) It averages another formula. If there are only lets say 50 data sets (quotes/lines) availaible the SMA averages < 100 lines. My envelope spreads because of that extrem at the left end of the chart. In Excel you havent this problem. Is it possible to catch/stop a SMA calculation in a spreadsheet if the number of quotes < length of the MA? |
[2019-09-20 04:36:51] |
Here's the formula for an SMA Skip Zeros. Maybe this would do what you want.the number of quotes < length of the MA? Or maybe you could modify this moving average study to start averaging dynamically: https://www.sawtoothtrade.com/free-stuff-18.html |
