Date/Time: Sun, 02 Feb 2025 15:59:02 +0000
DTC, POSITION_UPDATE message returns empty but position exists
View Count: 630
[2019-09-19 01:22:25] |
onnb - Posts: 662 |
I have a client connected to SC (SC running as server). I have "Trade Simulation Mode On" checked. I have position open in SC (I see it open on the chart) I send SC CURRENT_POSITIONS_REQUEST message. I receive back POSITION_UPDATE message with the correct RequestID, but the position is empty (no symbol, no quantities). All I see is the account "Sim1". This does not happen 100% of the time but it happens frequently enough. Is this expected with "Trade Simulation Mode On"? Do you have ideas what might be wrong? |
[2019-09-19 01:42:38] |
onnb - Posts: 662 |
I receive back POSITION_UPDATE message with the correct RequestID, but the position is empty (no symbol, no quantities). All I see is the account "Sim1". Update to this... I send SC CURRENT_POSITIONS_REQUEST message. I receive back from the server two messages Message1 - RequestID == 0, has the sybmol and position filled as I expected, Unsolicited is 1 Message2 - RequestID == K, I receive back POSITION_UPDATE message with the expected RequestID (K), but the position is empty (no symbol, no quantities). All I see is the account "Sim1". Unsolicited is 0 |
[2019-09-19 11:15:04] |
We do see some problems related to Trade Position DTC messages when using trade simulation in a server instance of Sierra Chart from a client instance. This will be resolved in the next release.
[2019-09-19 15:51:18] |
onnb - Posts: 662 |
What version # ?
[2019-09-19 16:16:17] |
1990.
