Date/Time: Thu, 02 May 2024 19:34:57 +0000
Spreadsheet values don't match whats on the chart
View Count: 650
[2019-09-18 18:27:31] |
User183724 - Posts: 183 |
i put the 'swing high and low' study on my chart. the arrows show up in the correct spot but their values in the spreadsheet for the chart is off by 10 points. anyone seen anything like this before?
[2019-09-18 19:03:54] |
update ...i refreshed the data and everything fixed. I guess something happened during the FOMC volatility and one of the arrows wasn't printed on the chart. when I tried matching the chart to the spreadsheet the missing arrow from the chart threw off my count on the spread sheet so I guess the spread sheet was the one with correct values and the chart had a missing arrow.
[2019-09-18 21:08:38] |
John - SC Support - Posts: 31328 |
Therefore, the issue would likely be due to a calculation order problem. This is documented in detail here: Chart Studies: Study Calculation Precedence And Related Issues For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-19 01:58:58] |
as far as I'm aware, the swing high and low study is independent and doesn't use other studies in its own calculations...please correct me if I'm wrong
[2019-09-22 20:00:49] |
But the problem is that study could be calculated after the Spreadsheet Study is accessing the study values. Refer to the documentation here and see what the calculation order is and see that it is calculated ahead of the Spreadsheet study that is referencing it: Chart Studies: How Calculation Order of Studies Is Determined Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-22 20:01:18
