Date/Time: Sun, 02 Feb 2025 15:54:57 +0000
want to disconnect from data
View Count: 529
[2019-09-18 17:00:07] |
User43523 - Posts: 3 |
HI- I'm not using SC now and want to terminate the data feed charge. Denali Exchange Data Feed and Exchanges Monthly Cost: 20 USD Can you do that for me? Kenneth |
[2019-09-18 18:42:25] |
This is already the case for the Sierra Chart account you posted this message with. There are no active services on it. But we have expressly disabled renewal of those services, if you were to add additional credit to your account. So at this point you are all set. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-18 18:42:57
