Date/Time: Sun, 02 Feb 2025 16:04:45 +0000
updated SC and lost an important feature on my dom
View Count: 754
[2019-09-18 16:23:50] |
User875891 - Posts: 63 |
I have updated my sc/cqg and have lost a very important feature on my dom it no longer saves the recent bid/ask information I have been using 1700 up until now as it saved that info Can you fix this? |
[2019-09-19 11:51:20] |
There could not be any problems with this functionality. It is not clear specifically what the problem you are describing is as these columns only hold the recent Bid and Ask volume anyway. Check all of the settings which affect Recent Bid and Ask Volume which are documented here: Global Trade Settings Windows: Chart DOM Settings And here are the descriptions for those market data columns: Global Trade Settings Windows: Chart/Trade DOM Column Descriptions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 11:51:57
[2019-09-19 12:29:54] |
here is a screen shot from version 1700 http://www.sierrachart.com/image.php?Image=1568895935754.png the 2 columns to the right are the recent bid and ask they remain visible till trade goes thru them in the newer versions this data does not remain Date Time Of Last Edit: 2019-09-19 12:33:29
[2019-09-19 15:54:50] |
after reading the info you posted it appears there is no way to adjust the milliseconds (recnt bid ask) on version 1700 are you stating that that option is available on newer versions? |
[2019-09-19 16:16:26] |
Uncheck the option for Reset Recent Bid/Ask Volume on Bid/Ask Change found on Trade >> Chart DOM Settings. Refer to the following: Global Trade Settings Windows: Reset Recent Bid/Ask Volume on Bid/Ask Change (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-19 16:16:38
