Date/Time: Thu, 02 May 2024 16:27:58 +0000
have text migrate with developing chart
View Count: 706
[2019-09-18 12:25:35] |
User283743 - Posts: 38 |
I am using the text tool to label lines on tpo charts (like "gap 09/09" etc.). So far I havent figured out how to have the text "migrate" to always appear on the right hand edge of the screen as time moves on and more profiles develop. Is that possible?
[2019-09-18 17:00:49] |
Use the Stationary Text tool. It does exactly what you are asking for. Refer to the information for that tool here: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-19 12:33:05] |
Hi, Im afraid the stationary text moves when scrolling up/downwards, but I need it to "stick" to the lines/levels I draw. (see screenshots of today's profile) http://www.sierrachart.com/image.php?Image=1568896248516.png http://www.sierrachart.com/image.php?Image=1568896174610.png |
[2019-09-19 23:20:09] |
Make sure this option is disabled in the properties for the drawing: Link to Vertical Axis Scale Refer to: Chart Drawing Tools: Drawing Tool Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-20 12:16:09] |
It works now as wanted , thank you. For future reference the "link to vertical axis scale " needs to be enabled/ticked for text to remain completely stationary. 👍
