Date/Time: Sun, 09 Mar 2025 20:52:33 +0000
DTC, MARKET_DATA_UPDATE_TRADE_COMPACT not being send with SC Data All Services
View Count: 802
[2019-09-18 00:35:21] |
onnb - Posts: 662 |
When using SC Data All Services / EURUSD, it looks like SC is not sending MARKET_DATA_UPDATE_TRADE_COMPACT Is that expected ? |
[2019-09-18 19:18:47] |
This depends upon the flags given for the Integer_1 field in the Logon Request: const unsigned int DTC_LOGON_REQUEST_INTEGER_1_LOW_BANDWIDTH_FLAG = 0x1; const unsigned int DTC_LOGON_REQUEST_INTEGER_1_RELAY_SERVER_MODE = 0x2; const unsigned int DTC_LOGON_REQUEST_INTEGER_1_SUPPORT_UNBUNDLED_TRADES = 0x4; const unsigned int DTC_LOGON_REQUEST_INTEGER_1_NO_COMPACT_MARKET_DATA_MESSAGES = 0x8; What are you specifying? But actually, in the case of a Forex symbol you are only going to get s_MarketDataUpdateBidAskCompact. There are no trades. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-18 19:20:32
[2022-03-09 01:15:08] |
onnb - Posts: 662 |
SC displays forex symbol time and sales using the mid and a volume of 1 Is it possible for you to add this functionality to DTC? |
[2022-03-09 01:20:19] |
No we would not do that. It is completely inconsistent with how market data is handled in Sierra Chart.
