Date/Time: Tue, 11 Mar 2025 07:42:02 +0000
Index chart for Nasdaq
View Count: 668
[2019-09-17 19:50:19]
User427371 - Posts: 14
Hi. I'm using AMP with CQG data. I'm enabled for Nasdaq cash index real time data through them. However, I can not find a way to open the chart. I've tried your own symbol $IUXX as well as the CQG through Amp symbols: ^NDX or NDX and those do not work either. I need to use the Nasdaq 100 index.
Please help me find a way to use this index with your platform. Thank you.
Date Time Of Last Edit: 2019-09-17 19:52:38
[2019-09-19 11:33:02]
You will find the correct symbols to use under File >> Find Symbol >> CQG Indexes.
Date Time Of Last Edit: 2019-09-19 11:33:17
[2019-09-19 13:04:43]
Found it and it's working! Thank you!
