Date/Time: Sun, 02 Feb 2025 15:58:24 +0000
Daily P&L on trade window
View Count: 1444
[2019-09-17 19:10:24] |
LucentTrader - Posts: 35 |
Is there a setting to remove the Daily P&L from the trade window?
[2019-09-17 21:00:34] |
Yes, refer to this particular setting: Global Trade Settings Windows: Display Daily Profit/Loss On Chart/Trade DOM (Global Settings >> Chart Trade Settings >> General >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-18 03:02:46] |
Actually, thinking about this, that does not remove it from the Trade Window. You need to set the Profit Loss Format in the Chart Settings to Do Not Display: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-18 03:03:45
