Date/Time: Sun, 02 Feb 2025 15:53:28 +0000
[Locked] - Chart Templates
View Count: 2361
[2019-09-17 14:20:35]
User94606 - Posts: 327
I am customizing the charts under Charts -> Graphics Settings - Chart and would like to save it as a template and use it for other charts. I do not want to use the Global Settings -> Graphcs Settings - Global because this will apply to all charts. Is there a way to save a chart template and use the template for other charts?
[2019-09-17 16:13:59]
Refer to the following:
Using Chart Templates
[2019-09-17 16:50:11]
Is there another option? With this option, I would need to duplicate/copy the chart. I was hoping to use existing charts and apply the templates. This is similar to how the studies can be apply where you can save the study set and load it onto any chart.
[2019-09-17 23:44:42]
User106180 - Posts: 88
I think the templates you have saved are available in the 'Analysis' menu. By selecting a chart, and then the relevant template from the 'Analysis' menu - it will apply this template to the selected chart.
[2019-09-17 23:49:59]
Yes, they are but these templates are only for indicators/studies. Can I do that for Graphic Settings - Charts? If so, can you please provide me with a reference on how to save the template for a Graphic Settings - Chart?
